Old 04-16-2007, 11:53 PM   #1
BillyTheChamp
BillyTheChamp is a jewel in the roughBillyTheChamp is a jewel in the roughBillyTheChamp is a jewel in the roughBillyTheChamp is a jewel in the roughBillyTheChamp is a jewel in the roughBillyTheChamp is a jewel in the roughBillyTheChamp is a jewel in the rough
Whats wrong with my sr20 ac?
i have a s14 with an sr20 red top.. the motor came with no ac belt on it so i tried to install one today.. when i put the belt on and started the car the compressor was spinning but the center spinning wheel on the compressor did not spin.. i was not getting cold air.. and yes i did press the ac button.. i checked the compressor fuse and swapped it out to make sure it wasn't a fuse, and it wasn't.. i'm pretty much stumped.. i'm moving back to Las Vegas soon and need to get my ac working.. any tips or advice?
Billy
BillyTheChamp is offline   Reply With Quote
Old 04-17-2007, 01:11 AM   #2
mandoz85
mandoz85 will become famous soon enoughmandoz85 will become famous soon enoughmandoz85 will become famous soon enoughmandoz85 will become famous soon enough
Is the A/C wired up? Is the system charged with freon? Most Sr swap do not have working A/C.
mandoz85 is offline   Reply With Quote
Old 04-17-2007, 01:17 AM   #3
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
check wires
use a test light or power probe on the fuse.
see if theres current going to it.
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 04-17-2007, 01:55 AM   #4
DoriftoPnoy
DoriftoPnoy's Avatar
DoriftoPnoy is on a distinguished road
are all the lines still hooked up? do you still have all the a/c parts? condensor, drier, blower, etc. might wanna check to see if you have freon too.
DoriftoPnoy is offline   Reply With Quote
Old 04-17-2007, 02:11 AM   #5
BillyTheChamp
yeah all the lines and everything is connected..and i do have the condensor, drier and blower and it does have freon in it as well.. all it was needing was the belt.. but after i put the belt on i dont know why the compressor did not start.. (spun, but the center plate did not spin).. i might have to check the wiring.. i dont have a test light so guess i need to go buy one.. anyone had any other problems connecting thier ac? is it possible to turn off your ac via ecu chipping? i know with honda's you can make ac cut out with hondata/chrome.. i didnt know much about 240 ecu tuning.. are there any fuses under the steering wheel that has to do with ac? (my little fuse reference plate under the dash is missing).. this is frustrating!
Old 04-17-2007, 06:54 AM   #6
jkjunior
jkjunior's Avatar
jkjunior has a spectacular aura aboutjkjunior has a spectacular aura aboutjkjunior has a spectacular aura aboutjkjunior has a spectacular aura aboutjkjunior has a spectacular aura aboutjkjunior has a spectacular aura about
Send a message via AIM to jkjunior
its possible whoever wired the sr20 harness to fit ur chassis never hooked it up. I belive its a yellow wire with green stripe if i remember correctly.
91 S13 Hatch- Old Lady Hit Me -Junk Yard
91 S13 Coupe Se- Junk yard
95 S14 Zenki Current
95 S14 Zenki Converted to Kouki SOLD
97 S14 Kouki - Junk Yard
89 S13 Hatch - SOLD
Feedback - http://www.zilvia.net/f/showthread.php?t=130589
jkjunior is offline   Reply With Quote
Old 04-17-2007, 07:31 AM   #7
S14DB
AFC #1
S14DB's Avatar
I haven't seen a S13SR->S14 with working AC. The wiring of the AC controls between the S13 and S14 is different and most people do not spend the time to rewire the two different systems together.
Old 04-17-2007, 01:29 PM   #8
BillyTheChamp
hmmm.. thats good to know.. i wouldnt think there would be much of a difference.. is there a manual out there where i can figure out the wiring?
Old 04-17-2007, 02:59 PM   #9
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I actually make conversion brackets that allow you to use the S14 KA compressor with your s13 redtop. No need to run R12, or have stuff welded...just bolt on and go.
Using an S13 SR compressor is odd, as you will need different lines, as well as a way to change the system over to R134a vs the R12 that they use overseas during those years. As far as the wiring is concerned, my harness from Yuri @ Wiring Specialties already had it wired in like it should be.
