Old 05-03-2007, 06:55 PM   #1
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
Stuttering at freeway speeds, stalls at idle.
1996 240sx, 0BD2. Stock KA, about 100k. miles, injen intake/custom exhaust. Just passed smog with flying colors(numbers were super low actually)
This is a very intermitant problem. It usually occurs on the freeway between the rpms of 3k and 4500. Doesn't matter if i'm flooring it or just cruising. Every once in a while it will also stall out at a stop light or when i just start if up and back out of a parking space.
When it stutters it feels like i loose spark or fuel, the car stutters for 2 or 3 seconds, then picks back up as normal. The car shows NO CELs...
I have TWO track events this weekend, so getting a little desperate.
Already replaced
Fuel Pump (with another used one)
Fuel Filter (was good, but replaced anyways)
Primary 02 sensor
Secondary 02 sensor
Intake filter is k&n, and fairly clean.
Cap, rotor, plugs, Plug Wires are a year old with about 5k. miles.
Gas is new, and always 91 octane
gotta240 is offline   Reply With Quote
Old 05-03-2007, 10:02 PM   #2
240on430
240on430 has a little shameless behavior in the past
clean the MAF?
240on430 is offline   Reply With Quote
Old 05-04-2007, 01:33 AM   #3
gotta240
will try. thanks for the suggestion.
Old 05-04-2007, 02:10 AM   #4
SR240DET
SR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud of
Send a message via AIM to SR240DET
if that dont work then... give this a shot because its cheap and free for the most part
http://www.zilvia.net/f/showthread.p...14+mafs+repair
SR240DET is offline   Reply With Quote
Old 05-04-2007, 08:05 AM   #5
gotta240
thank you sir.... will look into that!!!
Old 05-04-2007, 12:41 PM   #6
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
yah i r/p my MAF once already for the same problem and yet to fix it
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 05-04-2007, 06:01 PM   #7
gotta240
MAFS replaced and MAFS PLUG replaced.
Still having the same problem.
Old 05-06-2007, 01:01 PM   #8
idlafie
idlafie's Avatar
Check the ground wire directly above your oxygen sensor. It's towards the rear of the engine block on the driver side next to the firewall. Make sure the ground wires are firmly connected to the metal grommet that is bolted to the engine block and to the firewall. An intermittent short in the grommet & those wires can cause stumbling or worse yet not allow your car to start. You might have to cut the grommet off & resolder the wires to a new grommet.
I had this problem several years ago with my 95 S14. My car had been stumbling and stalling for several days while driving it. After doing some maintenance on it, I couldn't get it to start. Prior to working on it, the ECU didn't show any codes at all. After doing a tune up, swapping out the fuel filter, spark plugs, distributor cap & rotor, and cleaning out the air intake, the car didn't want to start. It was after doing all this work that my ECU started throwing MAF, Distributor, Fuel pump AND ECU codes. Turns out the engine block ground wire had a short. It took 3 weeks AND a trip to the stealership to figure out what the problem was.
It was funny cuz the dealer tried to tell me my ECU was bad, to which I brought in my friend's 95 S14 along with a spare ECU and demonstrated to them that the ECU in my car wasn't the problem. I knew there was a short, I just couldn't figure out where!!...
Anyhow, hope this helps...
ID
Old 05-06-2007, 01:37 PM   #9
gotta240
I'll check on that.... Thank you!!!
Old 05-10-2007, 04:49 PM   #10
pbcstylez
gotta240, did this fix your problem? i got a CEL today and it stumbled like all hell on the freeway
Old 05-10-2007, 05:37 PM   #11
slothonaleash
slothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond repute
vac leak(s)
message length
slothonaleash is offline   Reply With Quote
Old 05-10-2007, 07:29 PM   #12
gotta240
No vac. leaks... Followed all lines and found a vaccume leak(from intake pipe to intake manifold) but that didn't fix the problem.
Only thing left to try is EGR... Suggestions?
Old 05-10-2007, 09:22 PM   #13
lswang
lswang's Avatar
lswang is an unknown quantity at this point
i have the exact same problem on my car. it's been a year and i still haven't figured out the problem. LMK when you figure it out bro!
lswang is offline   Reply With Quote
Old 05-10-2007, 11:04 PM   #14
Zenki_S14
Zenki_S14 is an unknown quantity at this point
Might wanna check that used fuel pump. You'll might as well dish out $100 for a brand new Walbro. Haha.
Zenki_S14 is offline   Reply With Quote
Old 05-10-2007, 11:48 PM   #15
gotta240
I have a new walbro waiting to go on... The chances of getting two bad fuel pumps that cut out during the exact same circumstances is very low though..
I'm betting my fuel pump isn't the issue.
Old 05-11-2007, 02:30 PM   #16
lswang
lswang's Avatar
just for reference, this is what i have checked/changed so far so you can compare with me. i've check fuel pump, fuel filter, changed spark plugs/cap/rotor/wires, changed maf, cleaned maf connecter with electrical spray. and still, i haven't solved the problem
Old 05-11-2007, 02:34 PM   #17
pr0ject TRUENO
pr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfection
Send a message via AIM to pr0ject TRUENO
Clean the EGR and IAC. My old S13 had the same problem and when I cleaned it out worked like a charm.
Might also be your fuel pump.
pr0ject TRUENO is offline   Reply With Quote
Old 05-11-2007, 03:08 PM   #18
pbcstylez
where can i find this $100 walbro pump?
Old 05-11-2007, 03:50 PM   #19
pr0ject TRUENO
all over ebay
Old 05-11-2007, 03:51 PM   #20
gotta240
forget 100, i paid 85 bucks...
I believe they are a sponsor on this site... If you tell them you were reffered from zilvia, or use "zilvia" as a code, you get 15 bucks off... I just can't remember the name of the site!!! Someone else remember?
Old 05-11-2007, 04:08 PM   #21
pbcstylez
anybody anybody? sorry for my lack of motivation to look around this stuttering issues have caused me to abandon this project temporarily
Old 05-11-2007, 04:27 PM   #22
Canaduh
Canaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of light
Whoa whoa whoa. NEVER stop your project. =D
I had a similar issue, and i threw in a new fuel pressure regulator and it's never done it since. I recommend finding a used one, or jack one off your friends car, just to make sure before you go replacing parts. I work at a part store, and the part number for a new one is PR59, but you'll need to get it interchanged if you go for a new one.
Canaduh is offline   Reply With Quote
Old 05-11-2007, 04:28 PM   #23
arkive43
arkive43's Avatar
arkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud of
yea check/clean ur iacv that should help....
arkive43 is offline   Reply With Quote
Old 05-11-2007, 04:46 PM   #24
Canaduh
i could have sworn your IACV valve doesn't do a whole lot while cruising at 3500rpms.... i know it affects IDLE issues. News to me if that would fix this problem. Maybe i'm completely wrong though.
Old 05-11-2007, 05:03 PM   #25
vvtisupra
vvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond repute
Send a message via AIM to vvtisupra
bad ground dafdafdafda
http://www.fuckdrama.com/
vvtisupra is offline   Reply With Quote
Old 05-11-2007, 06:40 PM   #26
Zenki_S14
What about your distributor? If you have oil leaking into your distributor, it can cause a misfire as well. I'd take off the cap and look to make sure nothing's disrupting inside. Just a thought.
Old 05-11-2007, 06:57 PM   #27
gotta240
Grounds are good. All the grounds had about .05 resistance. Just to be sure i removed them, cleaned, and replaced.
The dizzy has no oil in it. As a matter a fact i JUST put in a new cap and rotor...Still no fix.
Also seafoamed through the brake vaccume. got a little black smoke and more white smoke, but nothing substancial. Still no fix.
I disconnected the egr by unplugging the vaccume and capping the line. Not sure if this will fix it. Also went out and got a Fuel pressure tester... I'm getting upset and ready to do something crazy!!! lol.
Old 05-13-2007, 10:27 AM   #28
slothonaleash
by now i would have thought the problem would have been fixed lol...
maybe bad fuel pump relay?
Old 05-14-2007, 11:23 AM   #29
pbcstylez
do the crazy!!!! i'm there with you....
Old 05-14-2007, 02:12 PM   #30
Dream240
Dream240's Avatar
The two things you should always check first is fuel pressure, and spark/timing.
Once you get the fuel pressure checked and that's not the problem, check your TPS voltage and kohms readings per the FSM.
You might also want to inspect your Crank Position Sensor. This problem sounds like a bad ground, and not necessarily a body ground. Your TPS has a ground wire connected to it, as do some other sensors. You might have some corrosion in a connector that's causing the short.
