#91 | |
Ermuel, if you're ever in san diego, let me know, i'd like to check your ride out, and i can show you how to make a ACT XTREME Clutch slip in my KA-T
![]() Quote:
#93 |
![]() Join Date: Jul 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
sent my ECU to Emance about 4 weeks ago...
got it back (5days later) and its was DOA!?? very confused, no injector signal from ECU, sent it back to Jason. he tells me a capacitor was leaking all over my board. and was trying to fix it, I mean, stuff happens like this all the time, its no ones fault. but this just feels like its taking forever, still waiting on the ECU and i will up date when i get it back.. ... edited ![]()
#94 | |
Chris, when i receieved your ecu, i noticed there was some corrosion on the bottom of the board. like i mentioned to you in emails this is something that happends to circuit boards that have been exposed to high heat/high humidity or water.
when i tuned your ecu, i hookd it up to my computer to make sure there are no short circuits, it passed. but when you receieved it, the injector was not firing, so you sent it back, i offered to look at it. like i said in previous emails, i will try to clean up the corrosion and patch some of the circuits but this is something that happends with circuits, it is not my fault, it just happends. i dont want you to be out of a car though chris, if the ecu is not repairable, i will tune another ecu for you free of charge. i dont want you to feel like you're screwed. see picture attached of chris's ecu (note you can even see how the corrosion is eating the screw): ![]() Quote:
#97 |
sorry i didnt mean to make it sound like YOU messed my ECU up, i do understand this stuff happens its just weird that it worked before i sent it out, i just hope everything works out.. thanx Jason.
#99 | |
#101 |
![]() Join Date: Jan 2004
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 21 reviews
didnt he tell you to take it to your local electronics repair shop and they would do it for you? Thats the best thing to do before you mess something up yourself.
#102 |
#103 |
#104 |
![]() Join Date: Sep 2005
I have s13 redtop sr, z32afm, gt28r, 555cc injectors, 3in exhaust, FMIC, megan fpr and safc.
Installing the board was like any other daughterboard install, header and cj2 jumper. First startup, safc 2in 6out, starts right up idles @ 1500rpm, then gradually goes down to 900 rpm... (startup enrichment 13.3) airflow was still .9 then @ 850~rpm airflow was .6 smooth idle. Noway 14.7 @ operating temps. stays there for 5 mins, thought wideband had frozen. revving engine changes afr , ok... cool. Zero out the SAFC, even decel. Go for a spin, nothing really just watching gauges seems. ok till dyno time. I'd like to do a gas milage comparison, then some hotlaps. I also want to see what the maps are doing via consult, time will tell. P.S. I have not removed the SAFC yet. Also I'm tuned for 91 but run 93. When I get on the dyno, obviously going to need to make changes, I just dont want to loose any power or torque.
#105 | |
Let me know how things go, you should be able to easily run 1.4 bar with that tune. you should notice some real power gains.
let me know how things work out! Quote:
#107 | |
anyone using it as a base for saftey or tune is not a tuner I would trust. please clarify what you mean by this. Do you have access to a personal/company dynometer? or outsource? Why not tune every car on the dynometer one by one? The power possibilties would be much higher and tune much better especially for midigating tuning effects of Cali gas and other influences. just curious
Like Me on FaceBook ![]() |
#108 | |
all our base maps are dynotuned.
for fine tuning we use turboxs knock lites (google it) and the bosch knock sensor turboxs recommends. it works beautifully it is so powerful it even detects mild knock. i advance/retard timing so there is not even mild knock (naked ear cant hear it) we could dyno tune cars one by one if you live local to san diego and are willing to pay. but for most people, or base tune will make you happy. Quote:
#109 |
yeah using a light to tune for knock is not my fortay but i suppose it could work in a pinch.
If i could data log the input from the sensor the knock lite unit uses then i might pick one up in the near future. im fine (tune my own goodies and others ems') but im sure there are people who arent willing to go standalone and could use your services. there is quite a meaningless monopoly on tuning in cali regarding stuff like this the more smaller people start up the easier it makes it for me to get some legitimacy as well, at least in the short term. cheers
#112 |
![]() that is an irrelevent test. if the parts have been submerged then they have not seen oxygen. for something to corrode or oxidize it needs the presense of oxygen. so yes, eventually e85 will eat your fuel system.
#113 |
![]() corrosion is funny like that. it will work great untill its disturbed and bang, it wont work after. thats pretty common for electronic stuff.
#115 | |
so i dont understand if it would corrode and eat the lines why they would install them at the factory. but to be ultra safe i ordered a methanol fuel kit. it comes with 6an teflon coated stainless steel fuel lines with all nitrile o-rings (methanol safe) |
#116 |
AFC #1
![]() Join Date: Oct 2003
Factory fuel lines are Aluminum which Alcohol loves to eat. Most 'rubber' fuel line these days is synthetic and Alcohol has less of a drying effect.
Just cause the parts are in one piece does not mean there is not surface oxidation and corrosion going on. I'm sure there is some residue at the bottom of the buckets. May work now but you will have FPR or injector failure in the future as deposits build up in the injectors.
#117 | |
![]() Quote:
mike |
#118 | |
![]() Quote:
#120 |
so i got my car was all set to get dyno'd today but my ecu was a lil messed up ...so i couldnt get any #'s yet , it was real rough on the start up then idle down a lil bit but kept bucking, it was real rich and the e manage couldnt comunicate with the ecu we took 50 % w/ no change ,i ve emailed jason and am trying to solve the problem but no luck yet..ill keep everyone updated to see how the tune works
