Old 05-17-2007, 02:50 PM   #1
soyer
soyer is an unknown quantity at this point
gauge temp sensor
recently bougth a s14 with redtop and the temp gauge goes to half way abotu 10sec after i startt he car and read max while driving but no over heating problems/ i tried changing the temp sensor with a new one made for doch ka but same problem anyone know what wrong?
soyer is offline   Reply With Quote
Old 05-17-2007, 02:52 PM   #2
jrmiller84
jrmiller84's Avatar
jrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond repute
Send a message via AIM to jrmiller84
Probably the gauge or a wiring problem. Go aftermarket.
BitDestroyer.com
jrmiller84 is offline   Reply With Quote
Old 05-18-2007, 04:18 PM   #3
soyer
no other way??
Old 05-18-2007, 04:21 PM   #4
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Check/add grounds, maybe? Usually bad grounds will make the needle bounce around, though.
Alex
e1_griego is offline   Reply With Quote
Old 05-19-2007, 06:52 AM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You need the S14 water temp sensor off your KA. The SR water temp gauge sensor has a different voltage signal. Go to the dealer and get it for whatever year your chassis is and swap the SR one out.
Just incase your not sure which sensor it is, look a bit above the thermostat area. Look at your wiring by the FPR and follow it, should go to 2 sensors. Swap the one on the right side.
CLICK HERE!!!
Old 05-24-2007, 07:15 PM   #6
soyer
thanks!!!!!!!!!! will try it out
