Old 05-24-2007, 07:07 PM   #1
05civse
05civse is making a name for him/her self05civse is making a name for him/her self
getting SR20 to 350-400 whp
So here is the deal, I have an S13 with a S13 blacktop SR20. The car used to feel fast for the first month that I was driving it, then I got used to it. I know it hasn't actually slowed down because it is still faster than the cars and bikes I raced when I first swapped it in. It has a built head with stock cams, stock bottom end, big FMIC, 3" turbo back exhaust, ect. (I’ll post the full list). I want to know some tried and true steps to make over 350 whp without too much boost (below 25psi). I plan on using a power FC for E/M. I would like to use the manifold it has on it (done a lot of custom work to it), but I could change it if need to.
I was looking at GT2871R's but haven't found any dyno graphs of them clearing 350hp. I know I don't want some huge turbo if I can get away with it. Basically, If you guys could list all the parts I would need (inj. size, turbo, ect.) to make a setup that can put down the numbers I am looking for that would be awesome.
Engine mods:
Engine:
 ’94 Blacktop SR20DET from 180sx
 XS Power turbo manifold (highly modified)
 XS Power turbo extension
 Crower Valve springs
 Crower Titanium Valve spring retainers
 Exedy stage one clutch
 Greddy V-SPL front mount intercooler
 Greddy aluminum oil pan
 Cometic headgasket (1.2mm I believe)
 New exhaust valve guides
 New valve seals
 Valve grind
 Ported head
 Head surfaced
 HKS SSQV blow off valve
 Walbro 255 LPH fuel pump
 300zx fuel filter
 Manual boost controller
 ARP head studs
 TC Sportline rocker arm stoppers
 Megan racing 3” flex down-pipe
 Megan racing 3” test pipe
 Motoria 3” cat-back exhaust
Thanks for the help!
05civse is offline   Reply With Quote
Old 05-24-2007, 07:14 PM   #2
Project3328
Project3328's Avatar
Project3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud of
cams, injectors, and fpr wud help
Project3328 is offline   Reply With Quote
Old 05-24-2007, 07:25 PM   #3
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
clutch
and some type of ems
gt2871r should get you in the ballpark, and go take it to a dynojet dyno
Wei240 is offline   Reply With Quote
Old 05-24-2007, 07:32 PM   #4
eastcoastS14
eastcoastS14's Avatar
yep i agree with these guys...740injectors, 255lph fuel pump, enthalpy rom tune, act clutch and get yourself a wideband while youre at it and you should be golden
and oh yeah spend the extra $$ and get yourself a good tune
eastcoastS14 is offline   Reply With Quote
Old 05-24-2007, 07:49 PM   #5
usdm180sx
usdm180sx's Avatar
If you go with an internal wg at that level I would lose the mbc and get an ebc just my 2 cents
-Norm!
Old 05-24-2007, 07:50 PM   #6
sliEighty
sliEighty's Avatar
sliEighty is making a name for him/her selfsliEighty is making a name for him/her self
Send a message via AIM to sliEighty
dont forget z32 maf... id try looking at gt2540r
livin on the east cost is harder then you think...
ECM for life lll
sliEighty is offline   Reply With Quote
Old 05-24-2007, 07:52 PM   #7
ctm_motortrends
ctm_motortrends's Avatar
ctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfection
Pulling 415 HP out of my S13 on a dyno.
ctm_motortrends is offline   Reply With Quote
Old 05-24-2007, 08:11 PM   #8
steve shadows
steve shadows's Avatar
Originally Posted by 05civse View Post
Engine mods:
Engine:
 ’94 Blacktop SR20DET from 180sxgood start
 Exedy stage one clutch make sure this is enough
 New exhaust valve guides yes
 New valve sealsyes
 Valve grind valve job-yes
 Ported headdoesnt do much dont need it
 Head surfaced of course
 300zx fuel filter
 Manual boost controller works with external wg, but not very well at all with ineternal diaphram
 ARP head studsworks ok if you torque to 80 ft lbs on final
everything i didnt comment on looks good.
sound like your going economical
Now on turbo choice, i would go top mout, 38mm tial wg, use the manual BC, use a .48 ar turbin housing t3 with a 50 trim t4 compressor wheel, stage 3 turbine wheel, to4e housing.
Cams will be a must, go 264 step II. hks or stage 3 brian crower
the setup changes i suggest will give you a solid powerband from 4k-7800rpms if you wanted.
I suggest Power FC for your EMS and have someone else tune it who knows what they are doing. Get the kit with the Map sensor if you can.
cheers.
Like Me on FaceBook !
Old 05-24-2007, 08:31 PM   #9
liv2drift045
liv2drift045's Avatar
liv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfection
Send a message via AIM to liv2drift045 Send a message via MSN to liv2drift045
i cant wait steve haha
but yea i was gonna say pretty much what steve did say.... if your gonna invest this much in a build FUCK XS POWER get something else
StreetSliders.Blogspot.com
liv2drift045 is offline   Reply With Quote
Old 05-24-2007, 08:38 PM   #10
eastcoastS14
my set up was:
s14 sr20
stock internals
T3/to4e 57 trim .63 a/r stage 3 wheel vband exit
custom made top mount mani
ssautochrome 38mm wastegate
deatschwerks 740cc injectors
walbro 255lph fp
fmic
z32 Maf
HKS filter
enthalpy rom tune
mild head work, port and polish
rebuilt block
hallman mbc
making 350rwhp at 17psi
Old 05-24-2007, 09:37 PM   #11
05civse
I did lots of welding, smoothing, and bracing to that manifold to make it look decent enough to install. As for engine management I was planning on going to a power FC and having it tuned by a well-known shop around where I live.
Top mounts look bad ass, but I am worried about the heat by the brake master cylinder. It gets hot mow and I have a ceramic-coated shield between it and the manifold.
I don't mind if I fry the clutch, I assume it will happen very soon if I can get that power.
The MAF will depend if I go to a MAP setup
So basically it looks like I need
**740cc inj.
**Possibly a Z32 MAF
**Manifold (depending on turbo)... I think I would like to stay bottom mount if I could fit it. Thoughts?
**Turbo. Lots of options it looks like. I am not all that hardcore into compressor maps and stuff so I am a little lost on this stuff, even though it is the most important.
** W/G depending on turbo. I also think I may want to stay internal if at all possible
** Power FC
** Cams.. What would the stock ones limit me around?
So I see like $3,500-$4,500 and some extra. What would you estimate?
Am I going a little overboard that I just want something that just feels really fast? To the people that are around this power, do you like it? Would you want more? Or is it about right?
Thanks so much for the ongoing help guys!
Old 05-24-2007, 09:59 PM   #12
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
you WILL need a z32maf. more then likely a differant clutch. top mount(suggested), gt2871r at the smallest i would suggest a gt30XXR, if you go topmount go to external WG and open dump(if you can get away with it in your area)
KA-T_240 is offline   Reply With Quote
Old 05-24-2007, 10:16 PM   #13
Nismoknightska-t
Location: Azusa, socal baby! why do i live this way?? it must be the money!
Nismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfection
Send a message via AIM to Nismoknightska-t
HKS GT-RS, 720in, Z32 maf, Power fc!!!!!!!!!!!!
Nismoknightska-t is offline   Reply With Quote
Old 05-24-2007, 10:25 PM   #14
eastcoastS14
HKS GT-RS if you want to buy an overpriced turbo....
to the OP keep your eye on the forsale pages...i just sold my t3 and 740injectors for $600 you can get pretty good deals if you keep an eye out...i got more turbo stuff fs if your interested
Old 05-24-2007, 11:04 PM   #15
staygold24
staygold24's Avatar
staygold24 will become famous soon enoughstaygold24 will become famous soon enoughstaygold24 will become famous soon enoughstaygold24 will become famous soon enough
stock manifold.
gt2871r .64
z32 maf
740cc injectors (deatschworks are cheap)
jwt s3 cams
tomei or apexi hg. not cosmetic.
arp headstuds are ok at 80ft lb as recommended earlier
enthalpy tune
now if you want 400whp then get the greddy intake manifold
good torque, good powerband and great reliability
Edit:Steve, what is your reasoning for always going top mount the t3/t4 50 trim?
gt2871r spools up sooner and can retain stock manifolds and everything and still make decent power. This is by no means a jab at you, I just always see you recommend it on here and also on freshalloy. Pm me if you dont want to clutter up the thread.
staygold24 is offline   Reply With Quote
Old 05-25-2007, 08:40 AM   #16
05civse
Well, the MAF depends if I go to a MAP setup with the power FC. I necessarily want 400hp just 350 and above. If going top mount would end up costing me an extra 2 grand for not that much power it wouldn't be worth it to me. although on the other hand, A better manifold wouldn't be a bad idea.
Lets say on a budget of $4k what could I Assembly and make good power on my stock bottom end. Keep in mind I would run lower boost just driving around and I don't want to blow my bottom end up the first month by way over working it.
Old 05-25-2007, 08:58 AM   #17
drifting_changed_mylife
drifting_changed_mylife's Avatar
drifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymore
Send a message via AIM to drifting_changed_mylife
THATS PRETTY GOOD! WHATS UR SET UP???
your neg reps match my avitar.... keep em commin
drifting_changed_mylife is offline   Reply With Quote
Old 05-25-2007, 09:07 AM   #18
DOOK
DOOK's Avatar
I just so happen to have a T3/To4e AR .60 exhaust .63, stage 3 wheel, top mount manifold custom made to pull the turbo further away from brake booster and master cylinder and also clear S14 stuff like I have installed on my S13, TiAL 38mm and Q45 MAF. It's all at a FRACTION of your estimates bro. I'll take 1300 plus actual shipping. All stuff is brand new, 0 miles. Came upon some rough financial times and I've had to abandon the project for now.
here is a link.
http://www.zilvia.net/f/showthread.php?t=144821
PM me if interested.
DOOK is offline   Reply With Quote
Old 05-25-2007, 02:08 PM   #19
05civse
What is everyones thoughts on that? ^^^^^ looks like it has been sitting a while though. sounds interesting
Old 05-25-2007, 02:33 PM   #20
DOOK
DOOK's Avatar
been sitting since november
<------ Grumpy Old Asshole
Old 05-25-2007, 02:37 PM   #21
liv2drift045
thats a go... and its a pretty good deal too all you need is a downpipe.... thats a similar setup to what steve recommended just slightly larger... it might be a LITTLE more laggy but not undriveable I say DO IT
Old 05-25-2007, 02:39 PM   #22
DOOK
DOOK's Avatar
Originally Posted by 8ggalant View Post
thats a go... and its a pretty good deal too all you need is a downpipe.... thats the exact setup i plan on running for the same powergoals you have.. DO IT
come get it
Old 05-25-2007, 02:42 PM   #23
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
gt2871r .64 will hit 350whp, some have hit 400whp (codyace). You can stay bottom mount and you will have full boost by 3500rpm
as everyone else said, wideband, 740cc injectors, z32 maf if going maf, rom tune if not going standalone, and a good set of cams
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 05-25-2007, 02:45 PM   #24
liv2drift045
Originally Posted by Ltdnismoracer4 View Post
come get it
Haha caught me while I was editing. I don't have the loot right now man AND the exact turbo I want (the one Steve mentioned above) one of my buddies is holding for me.
Old 05-25-2007, 02:48 PM   #25
DOOK
DOOK's Avatar
I'm not picky about buyers, either of you can get it haha
Old 05-25-2007, 05:23 PM   #26
05civse
^^ thinking about it. I just dont know a ton about turbos, so I am waiting to hear what all those seasoned vets. on here have to say. How much did you pay for all that? if you don't mind me asking. It would be fun!
I was also thinking about a 3071R with a t2 housing (i heared they made it)
Old 05-25-2007, 05:36 PM   #27
Tearlessj
Tearlessj's Avatar
Where did you get that top mount and how much?
Tearlessj is offline   Reply With Quote
Old 05-25-2007, 07:23 PM   #28
DOOK
DOOK's Avatar
PMed buddy
Old 05-25-2007, 07:25 PM   #29
DOOK
DOOK's Avatar
are you talking to me?
Old 05-25-2007, 07:44 PM   #30
05civse
anyway, I think I may be loosing my mind. Now I am seriously considering pulling the engine and rebuilding the bottom end with forged pistons and new rods. I just noticed my front main seal is leaking a little, and I'm burning oil I figure out the rear turbo seal.
I don't know, the current bottom end gives me perfect comp. and 2% or 3% leak down on each cyl. (all the same). Would it be worth it to build it up? should I just say f it all and go to an rb25? I am questioning everything now.
I need some encouragement so I just don't give up.
choices:
-fix front main seal, then go to a bottom mount gt3071R, power FC, and big injectors ---like $3-$3,500
-Build bottom end, go to a T3 topmount, power FC, and big injectors--Like $5000
-sell SR, go to RB25 mildly stock --like $4,000
Would a built SR be way more fun than mild RB? Horsepower is horsepower i guess.
