Old 05-25-2007, 09:45 PM   #1
BILLYhoang
BILLYhoang's Avatar
BILLYhoang is on a distinguished road
Send a message via AIM to BILLYhoang
Question what tire size for 18x10 J+0 and 18x12 +13 ?
wassup fellas again . thanks to zilvia and input from other forums , i went ahead and just purchased a set of wheels that I have been trying to research and see if it fits . I've always liked WORKS and wanted to get VSXX or Meisters S13P for my SUbaru but it wouldnt look as nice as they would on 240s .
so I got a chance to get some WORK wheels and I was planning to get some WORK Equips but fell in love with the VS-XX .
the size i went with is
Work VS-XX
and i plan to run 30mm fenders on the front and either 30mm or 50mm over fenders on the rear depending which would fit better .
here are the pics of the wheels , i should be getting them in about a week .
and they will be going on this car
and now I need some input and opinions on another question ...
what size tires should I run ?
the car is making a little over 300 whp at the moment but I would like to get close to like 380whp .
I do plan to use the car to drift . ( try to learn ) so not sure if that matters on tire selection and might go with either Bridgestones or Dunlops .
so I need your input fellas about what size tires and which model Bridgestones or Dunlops ? I think with Dunlops , I would be going with Direzzas ?
thanks
-- Billy
BILLYhoang is offline   Reply With Quote
Old 05-25-2007, 10:11 PM   #2
liv2drift045
liv2drift045's Avatar
liv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfection
Send a message via AIM to liv2drift045 Send a message via MSN to liv2drift045
Tire size is going to depend on ride height, camber and offset. I honestly have no idea what size you should run but this is what i think should work.
235/40 up front, 255/35 or 255/40 rear
StreetSliders.Blogspot.com
liv2drift045 is offline   Reply With Quote
Old 05-25-2007, 10:14 PM   #3
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
if it's drifting just get something cheap like federals...you're just going to burn them off anyways
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 05-25-2007, 10:23 PM   #4
arkive43
arkive43's Avatar
arkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud of
235-35front//255-35 rear
arkive43 is offline   Reply With Quote
Old 05-25-2007, 10:26 PM   #5
chmercer
chmercer's Avatar
235/40/18 is a terrible tire size. run 245 or 255/35 up front. rear run 265/35 or 285/30. 285/30 is better but some people dont want that much stagger. but if you run the 265/35 itll kindof mess up the rolling diameter. but it works.
you guys are smoking crack rock if you think you can get a 255/35 mounted up on a 12. and 235/35 only comes in 19.
also that rear is probably going to need a bit of a spacer
chmercer is offline   Reply With Quote
Old 05-25-2007, 11:22 PM   #6
drift_ricer
Banned from the Marketplace
drift_ricer is on the path to ruindrift_ricer is on the path to ruin
if it for stretch,
use 225/40/18 front
275/35/18 rear
these tires are on my work equip
drift_ricer is offline   Reply With Quote
Old 05-25-2007, 11:28 PM   #7
liv2drift045
While i dont know about mounting a 255/35 thats why I said or 255/40 because I know for a fact thats possible, and whats wrong w/ 235/40??
Old 05-29-2007, 11:15 AM   #8
BILLYhoang
BILLYhoang's Avatar
anymore inputs guys .. will be needing to order tires within the next few days , and to those who did give input , i appreciate it alot . thanks
Old 05-29-2007, 02:58 PM   #9
TforTits
TforTits is making his/her stupidity well-knownTforTits is making his/her stupidity well-knownTforTits is making his/her stupidity well-knownTforTits is making his/her stupidity well-knownTforTits is making his/her stupidity well-known
[quote=8ggalant;1391548]and whats wrong w/ 235/40??[/qu
Its stupid tall for no reason
the only reason to run 235-245/40/18s is because they're cheaper than 245-255/35/18s by about 50$ per.
TforTits is offline   Reply With Quote
Old 05-29-2007, 04:43 PM   #10
liv2drift045
both statements true, so you give or take... but it'll work
