Old 05-25-2007, 01:40 PM   #1
yoteru
yoteru is an unknown quantity at this point
loud humming/vibrating in right rear
whenever i drive about 40mph there is a loud humming/vibrating coming from the right rear area. its not inside there car, so its not just the interior pieces vibrating. its pretty loud to where you have to almost yell to talk to someone in the car.
i jacked up the car and the wheel bearing isnt loose or anything like that...i also looked at the suspension pieces and everything looks ok.
does anyone know what this might be?
thanks for any help
yoteru is offline   Reply With Quote
Old 05-25-2007, 01:45 PM   #2
ecuastyle84
ecuastyle84's Avatar
ecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to all
Send a message via AIM to ecuastyle84
did you check your rear right axle?...i had the same issue with my old hatch and it turned out to be the axle being loose...it was weird but i got it fixed
ecuastyle84 is offline   Reply With Quote
Old 05-26-2007, 04:50 AM   #3
LFOabuse
LFOabuse's Avatar
LFOabuse is making a name for him/her selfLFOabuse is making a name for him/her self
The wheel could be out of balance.
LFOabuse is offline   Reply With Quote
Old 05-26-2007, 05:57 AM   #4
misfitsfreak81
misfitsfreak81's Avatar
misfitsfreak81 is an unknown quantity at this point
most likely a wheel bearing. is it s13 or s14? the s14 is a selfcontained sealed unit. they likely wont feel loose, the humming or grinding is from them being too tight, rusty, worn out, ect... mine do the same thing. pretty damn anoying to say the least. but also pretty expensive to replace. i guess just live with it as long as you can.
misfitsfreak81 is offline   Reply With Quote
Old 05-26-2007, 05:58 AM   #5
misfitsfreak81
oh, also check the tire tread. if you have weird wear or flat spots it will also cause that same type of noise.
Old 05-26-2007, 10:43 PM   #6
overb0ost
overb0ost's Avatar
overb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to behold
which bolts? the lock nut or the ones that connect to the output shafts?
i have a similar problem with the sound but it goes away after 120km/hr
im thinking maybe my studs are warped.
overb0ost is offline   Reply With Quote
Old 05-27-2007, 09:53 AM   #7
ecuastyle84
