#1 | |
![]() Join Date: Apr 2003
honestly, not that many local auto parts guys knows theyre chits.
LP stylez!! bishes Lazy Penguin since teh 04' ![]() ![]() ![]() Part of the Elite Shasta Speed Stars RIP......05-09-03....*sniff sniff ![]() the beast nears completion..... ![]() YOU LOOK AND U BUY STUFF !!!!! |
#2 | |
where the hell have you been alex |
Run the largest possible plug gap you can without misfiring.
This will garner the best HP and toruqe as well as power band, throttle response and most importantly gas milage. Strength of spark is important when it comes to this. .030 is a good spark plug gap for 15-20 PSI depending on ocatne. But ive run .030 into 22+ psi ranges. Its all in the tune and supporting mods. anyways don't mean to confuse you, but there is no one size fits all when it comes to tuning and plugs/gap. 7 range is plenty btw, 8 is overkill.
Like Me on FaceBook ![]() |
#4 | |
![]() Join Date: Mar 2005
![]() ![]() ![]() Feedback Score: 2 reviews
Also, another small question, anyone know what's the best place to run lines for gauges throught the firewall on an s14? I want to install a boost guage and a oil pressure gauge. And any good wrietups on oil pressure gauge installation?
![]() Join Date: Oct 2006
pretty simple...if you look in the engine bay youll see rubber grommets in the fire wall....theres some on the passanger side, my guages were run behind the dash and through the grommets, usually if you pull of your glove box and have a friend shine a light through the grommet you can find the hole pretty easy but you may have to cut away some of the material to make the hoses and wires fit through
also be sure to cover the area that will be in contact with the firewall with something so that theres no chance of the metal rubbing through |
#7 | |
