![]() Join Date: May 2007
I'm not sure if any of the detachable hubs allow you to keep your horn...you'd need room in the hub for the continuous contact grounding ring for the horn wires, and the spring loaded contact points on the outer part of the hub. Easiest fix would be to use a coiled wire with a mommentary switch attached to one of your wheel spokes.the coils would allow you to turn your wheel without pulling the wires loose. As far as your cruise control, get ahold of a wiring diagram to determine what wires you need to start with from the colume. Sounds silly, but your local stereo shop prob has an installer that could wire up a toggle or 2 and the nessacary mommentary switches (all instaled in your dash) to have you CC fully functional.
![]() GT3076r-boosted blacktop sr20det, s13 coupe Function over Form... |
![]() Join Date: Dec 2002
The cruise plug is in the column, you can run it elsewhere or extend the wiring and mount the switch somewhere under the dash or flush it in. For the horn, just mount a pushbutton on the front of the column cover, it's not to janky looking and still easy to access.
