Old 09-20-2002, 02:53 PM   #34
kextyn
kextyn is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (allmotorKA @ Sep. 20 2002,02:21)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (misnomer @ Sep. 19 2002,5:11)</td></tr><tr><td id="QUOTE">I wanna know more about your car, allmotorKA. . . Looks to be SOHC KA with individual throttle bodies, upgraded fuel system, can't tell much beyond that. Looks very very impressive.</td></tr></table><span id='postcolor'>
Yeah its a KA24E with TWM individual throttle bodies. I also have a worked head with a Nissan Motorsports "R4" cam, HS header and N1 exhaust. Because the ITBs do not use an MAF sensor, the fuel injectors are controlled by a Haltech F9A ecu. The ignition is still controlled by the stock ECU...that's why I'm looking into changing the distributor to a mechanical/vacuum advanced type (still doing research on the best alternative distributor).
I'm not to happy with the HS header (I think the runners are paired improperly) and may end up just porting the stock exhaust manifold and using that. We'll see...stay tuned.</td></tr></table><span id='postcolor'>
There was some show like Two Guys Garage where they were building up an old Cobra. The only part I saw was about the distributor which was a mechanical/vaccuum advance type(I think). They build the distributor based on what you need...might wanna check into it. Their website is www.twoguysgarage.com and go to the second page of the previous shows. Its an DUI unit I believe. I'd love to find out more about doing an individual throttle body setup...I'm not much of a turbo guy and the idea of ITB is nice.
kextyn is offline   Reply With Quote
