Old 06-27-2007, 09:57 AM   #1
papi13
papi13's Avatar
papi13 is on the path to ruinpapi13 is on the path to ruin
s13 Funny feeling when hitting 60mph
When I drive between 60 and 68 mph my steering wheel shakes....does anyone know why???
papi13 is offline   Reply With Quote
Old 06-27-2007, 09:59 AM   #2
vvtisupra
vvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond repute
Send a message via AIM to vvtisupra
balance your tires.
http://www.fuckdrama.com/
vvtisupra is offline   Reply With Quote
Old 06-27-2007, 12:15 PM   #3
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
Or check steering rack or tie rods? Just a helpful suggestion..
Okinawandrifter87 is offline   Reply With Quote
Old 06-27-2007, 12:23 PM   #4
sleepy_s13
sleepy_s13's Avatar
sleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to behold
are your rear tires bald? that used to happen to me sometimes
K:\pics\Cars\new sig bridge copy.jpg
sleepy_s13 is offline   Reply With Quote
Old 06-27-2007, 12:45 PM   #5
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
+2 for balancing your tires
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 06-27-2007, 12:51 PM   #6
Kaotik25
Kaotik25 has made poor choicesKaotik25 has made poor choicesKaotik25 has made poor choicesKaotik25 has made poor choicesKaotik25 has made poor choicesKaotik25 has made poor choices
balance your tires, get an alignment check. This will definitely stop the steering vibration at 55-70mph. I had the same problem.
Kaotik25 is offline   Reply With Quote
Old 06-27-2007, 05:24 PM   #7
tangch
tangch is an unknown quantity at this point
+1 I had same problem too.
tangch is offline   Reply With Quote
Old 06-27-2007, 06:10 PM   #8
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
past 45 mph... both your wheels need to be balanced...
between 60-70mph... only one of your wheels need to be rebalanced...
check both wheels anyway... don't worry about balancing your rears....
http://www.thenismoshop.com
swayray is offline   Reply With Quote
Old 06-28-2007, 05:43 PM   #9
papi13
papi13's Avatar
thanks everybody but one of my tires in the back is bigger than the others...all tires are 205/55 the other one is a 215/55 does that have to do anything with it too???
Old 06-28-2007, 05:51 PM   #10
alexkosheck
alexkosheck has made poor choicesalexkosheck has made poor choicesalexkosheck has made poor choicesalexkosheck has made poor choicesalexkosheck has made poor choicesalexkosheck has made poor choicesalexkosheck has made poor choices
Dude...why did you do that?!
I'm curious.
alexkosheck is offline   Reply With Quote
Old 06-29-2007, 11:59 AM   #11
papi13
papi13's Avatar
I'm curious.
one of my tires blew out and i was broke so my friend gave me a brand new tire for free
Old 06-29-2007, 12:11 PM   #12
axiomatik
axiomatik's Avatar
no, that's not likely to cause your steering wheel to shake. first get your wheels balanced, then if the problem continues, get an alignment. But you should put that larger tire in the front, it's not a good idea to run different sized tires on your drive axle.
Old 06-29-2007, 12:15 PM   #13
papi13
papi13's Avatar
well i had the bigger tire in the front but on every bump that i hit the tire tore my wiring harness up
Old 06-29-2007, 12:43 PM   #14
axiomatik
axiomatik's Avatar
then relocate your wiring harness
Old 06-29-2007, 12:56 PM   #15
papi13
papi13's Avatar
thx everyone
Old 07-04-2007, 07:04 AM   #16
SilEightyKid
SilEightyKid is an unknown quantity at this point
I say check your engine mounts...
SilEightyKid is offline   Reply With Quote
