Old 07-18-2007, 03:58 PM   #1
Wahl 136
Wahl 136's Avatar
Wahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to all
Help me fix my work computer so I don't get fired!
The computer is running on Windows 2000 (POS ). Anyhow, the person that worked there last gave themselves Admin rights to the computer so now nobody can log in to the computer. On top of that there are files that need to be retreived still and my boss is riding my ass to come up with a solution.
So the question is when the windows prompted username/password screen comes up, after you first turn it on is there a way to override the existing password? Or atleast change the password without losing prior work?
Wahl 136 is offline   Reply With Quote
Old 07-18-2007, 04:31 PM   #2
S14DB
AFC #1
S14DB's Avatar
NTFS? Encrypted File System?
Old 07-18-2007, 04:51 PM   #3
Wahl 136
Wahl 136's Avatar
There is no encrypted file system. I know of NTFS but I don't believe the system runs on it. The network comprises of 6 work stations and 3 laptops.
It's verizion DSL with wireless hub, there is no spyware or encryption on the computer. As far as I know the program files / user accounts is the only thing preventing me from giving myself the admin rights. But I still lose my files if I don't get in to the current admin account.
Old 07-18-2007, 05:03 PM   #4
sikkk240
sikkk240's Avatar
sikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond repute
Send a message via AIM to sikkk240
have you tried guessing a few obvious passwords?
like - admin
ive also just pressed ok, and it let me in, without a password.
Try contacting the guy that used to work there.
I hope that helps man..
tell your boss, i said hes an asshole.
sikkk240 is offline   Reply With Quote
Old 07-18-2007, 05:26 PM   #5
Wahl 136
Wahl 136's Avatar
like - admin
I tired all the obvious stuff, admin, password the name of the company the name of the worker to no avail.
haha I would tell him that but then I would definatly get fired.
Old 07-18-2007, 06:10 PM   #6
sikkk240
sikkk240's Avatar
damn..
well good luck, i hope you dont get fired.
Old 07-18-2007, 06:25 PM   #7
delphis
delphis has a spectacular aura aboutdelphis has a spectacular aura aboutdelphis has a spectacular aura aboutdelphis has a spectacular aura aboutdelphis has a spectacular aura aboutdelphis has a spectacular aura about
pull out drive put it into another machine or an external case. take out important files and then reformat drive. problem solved.
as for getting around the password try searching google for a way around an admin password. since windows 2000 was mainly used in business applications, they did implement a way to get around the password just in a case like this. it might involve going in and editing some files in dos but I have never worked with 2000 but I used to do it in NT(predecessor) to 2000. if not call microsoft.
delphis is offline   Reply With Quote
Old 07-18-2007, 06:26 PM   #8
s13rookie
s13rookie's Avatar
s13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant future
Send a message via AIM to s13rookie
couldnt you just pull the hdd out and run it as a slave of another comp?
Edit: NM, i type too slow
Ive spent most of my money on cars and women...the rest i wasted
s13rookie is offline   Reply With Quote
Old 07-18-2007, 06:59 PM   #9
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
http://www.petri.co.il/forgot_admini...r_password.htm
Old 07-18-2007, 10:05 PM   #10
LB.Motoring
LB.Motoring's Avatar
Ive done it Via Safe mode,
creating a new admin user,
getting in that way.
Robby Leuer
Old 07-19-2007, 02:23 AM   #11
ixfxi
Guest
Posts: n/a
Win2k rocks, I still run that shit because its quick and stable.
If there's an account that you can login under, you may be able to change the admin's password (if you have enough access).
Otherwise, you can just re-install over that copy of windows, or hook the drive up as a slave.
Old 07-19-2007, 03:34 AM   #12
Vision Garage
Vision Garage's Avatar
Vision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfection
Send a message via AIM to Vision Garage
yea, hook it as a slave and then change your master to be the new admin of the files. Then you can access all the data. After you get what you need, reformat and tell your boss to give you a raise!
Vision Garage is offline   Reply With Quote
Old 07-19-2007, 09:46 AM   #13
ixfxi
Guest
Posts: n/a
or better yet, if your boss is a woman
ask for a blowjob, it always works.
Old 07-19-2007, 09:53 AM   #14
myriad
myriad is an unknown quantity at this point
Send a message via AIM to myriad
get an external hard drive, plug it in (if possible). Download Knoppix (http://www.knopper.net/knoppix/index-en.html) and get their live CD. Pop that in - load it up - you should then be able to view your hard drive on the computer. Find files, drag to external hd, give to boss.
In regards to the password.. meh.. there are plenty of utilities on the web to let you reset/alter/remove the password for the admin account.
Woot.
: S14 :
myriad is offline   Reply With Quote
