Old 07-27-2007, 09:28 AM   #1
Dream240
Dream240's Avatar
Stereo install ~ crossovers
Hey I just installed my Infinity Kappa 62.7i speakers last night and I have a question.
With concern to crossovers, do you need to let them vent for overheating purposes? I've never had to install them so I have no idea. I wouldn't think so which is why I wrapped them in the packaging plastic to keep them safe from the elements since I mounted them inside the door just above the speaker.
Anyone know? Thanks.
BTW the Infinity Kappa series ROCKS!!! Best speakers I've ever bought and I've been through quite a few brands.
Old 07-27-2007, 11:34 AM   #2
Ninjabread
Ninjabread's Avatar
I have the same question, gonna be mounting some pheonix gold (relics haha) with some crossovers.
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 07-27-2007, 11:46 AM   #3
projectRDM
projectRDM's Avatar
There's plenty of airflow within the door. You're fine.
FORMERLY R240NA
Old 07-27-2007, 12:02 PM   #4
ixfxi
Guest
Posts: n/a
crossovers dont get hot enough to need any special airflow accommodation.
Old 07-27-2007, 12:12 PM   #5
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
I put mine under each seat. So where did you put your tweeters? on the door?
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 07-27-2007, 12:43 PM   #6
Dream240
Dream240's Avatar
It's a 2-component speaker so the tweeter is midmount. They sound really crisp and clean. No noticable ambient noise or distortion.
Thanks R240 that's what I figured, just wanted some confirmation. And yeah ifixi, I didn't think it was a hot running device just by the construction of the component.
Thanks guys.
Old 07-27-2007, 08:29 PM   #7
s13rookie
s13rookie's Avatar
s13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant future
Send a message via AIM to s13rookie
there shouldnt be an issue with cooling, but i was always taught to never mount the crossovers in the door. It would be just as easy to stash them under the kicks and they wouildnt be getting slammed around.
are you running them off the deck or an amp?
Ive spent most of my money on cars and women...the rest i wasted
s13rookie is offline   Reply With Quote
Old 07-27-2007, 08:54 PM   #8
Dream240
Dream240's Avatar
I'm running them off an amp. As far as getting kicked around, you mean by the opening and closing of the doors right?
Old 07-27-2007, 09:02 PM   #9
s13rookie
s13rookie's Avatar
Yeah, it doesnt take much to pop soldering. If you are running them off an amp, place the crossovers right near the amp. since its a passive system, it doesnt really matter where the crossovers go in the chain.
Im not fam. with your set of cross's, but i imagine they have some type of adjustment on them, even just a tweet -3db or something. It would be a bitch to have to pull the door apart to get to them just in case you decide to start tweaking
Old 07-27-2007, 11:23 PM   #10
MAGILLA
MAGILLA's Avatar
MAGILLA will become famous soon enoughMAGILLA will become famous soon enoughMAGILLA will become famous soon enoughMAGILLA will become famous soon enoughMAGILLA will become famous soon enough
air flow will be fine almost anywhere like they said and the plastic wrap is a good idea if you are going to mount the x-overs in the door. I have an 95 se that has the factory location for the tweeter, in the a pilar. My crossovers are behind the driverside kick panel and behind the dash on the other side. I know my windows leak a bit so I didn't want to take the chance.
MAGILLA is offline   Reply With Quote
Old 07-28-2007, 01:11 AM   #11
95Blue240sx
I was so happy that my new speakers fit. The tweeter fit right in the old spot on the pillar with little modification to the original tweeter bracket.
Old 07-28-2007, 04:52 AM   #12
JDMClifford
JDMClifford's Avatar
JDMClifford is an unknown quantity at this point
umm, ya might want to mount tweaters right by the amps, and you shouldnt have a problem with overheating as long as you dont turn the amp way up. i melted the plastic covers on my crossovers because i did that. they should be fine by the amp.
Parking lot pimping
JDMClifford is offline   Reply With Quote
Old 07-28-2007, 10:21 AM   #13
Dream240
Dream240's Avatar
thanks clifford, I learned about the gain settings with my last set of speakers. Popped one of them after only a couple months.
As far as the x-overs settings, the +3 DB adjustment is part of the tweeter itself. You simply twist it to the left to up the db and right to set it at 0.
Here's the set I bought:
http://www.infinitysystems.com/car/p...=US&Region=USA
Thanks for the input guys.
Old 08-14-2007, 10:22 AM   #14
ewuzh
ewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of light
I've got an SE too and I was trying to install tweeters into the stock location last night but I couldn't get the A-pillar off. Any tips to remove the A-pillar? Do I just pull really hard or does the entire dash need to be removed?
ewuzh is offline   Reply With Quote
Old 08-14-2007, 01:33 PM   #15
chuonthis
chuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the rough
Sorry dude, the entire dash has to be removed as well as the front bumper...
Just kidding, it's held on with 5 clips. Pop them off from the back of the car forward. Just grab and pull down. There aren't any clips in the farther parts of the diagonal.
chuonthis is offline   Reply With Quote
Old 08-15-2007, 09:55 AM   #16
95Blue240sx
^^^ LOL Yeah he's right. You need to follow the A-pillar trim up and you'll see it is separate from the back trim, right above the seat. Pull it from the top and it should just pop out.
