Power FC and BEE*R
hi everyone, i try to install Bee*R into my SR20DET Redtop. I have Power FC, is this effect anything to my Power FC. Is install for my Bee*R going to be the same with other installation. Please help me, i dont want to burn my PFC. Thanks
A earth grounding issue has to be resolved if a vehicle is fitted with an aftermarket APEXi Power FC unit. This grounding issue is due to a lack of a ground terminal in the APEXi unit. The REV LIMITER uses the ground signal to cut off the ignition signal from the ECU. Since APEXi Power FC is a piggy back computer, and manipulates the original engine parameters' signals from the ECU before re-routing these modified signals to the vehicle individual engine components, a separate grounding signal is required from the APEXi Power FC. Once this grounding issue has been resolved, the REV LIMITER will be able to function as it is intended to be.
![]() Join Date: Nov 2004
Shut up unless you have shit to say that is of use.
You don't need the Bee*R rev limiter; assuming that's what you're talking about since you didn't specify... The Power FC's have built in rev limiter settings. I know for sure the Pro has an ignition based limiter. I'm not sure on the regular ones. I know they have a rev limiter also but it might be fuel cut based which would be pointless. You don't need to worry about the Bee*R limiter affecting anything though. As long as you program and wire everything properly you have nothing to worry about.
#7 | |
![]() Join Date: Oct 2006
![]() Join Date: Nov 2005
From what I read on other sites....
Yellow Wire - 180* pin on ECU Green Wire - 1* pin on ECU Red Wire - 12V IGN pin on ECU Black Wire - Ground pin on ECU (On PowerFC's you may need to add an extra earth from this pin to the chassis for extra grounding). --------------------------------------------------------------------- When my Power FC reaches rev limit it cuts fuel and my A/F ratio spikes to 13:1 under high load ![]()
you guys wouldn't be able to help me out would ya i need the 180* wire color and 1* wire color for an s14 Blacktop i have the bee*r rev limit to havin troble with install and i searched but couldn't find anything
![]() Join Date: Sep 2006
GTFO^. fag.
It's not that hard to stick some wires into a ecu. if you cant do that you should not own a s-chassis. What your asking about the wire colors was said above.
Function. Form. Step Up Drift Club/Upper Limit! |
#15 |
![]() Join Date: Aug 2006
Power FC Does Have REV LIMITER settings in the RPM System menu. Also, there is no Ignition Based Cut Rev Limiter, the Rev Limiter is Fuel Cut based in the Power FC. The only way to add an Ignition cut based Rev Limiter is to install some type of Ignition Cut system. I personally am not too familiar with the BEE*R stuff.
This is per Masaki at in Apexi. I spoke to him this morning. Apexi PFC Dealer & Tuner Susan Adrenaline Motorsports Inc www.adrenalinexxx.com |
#17 |
#19 | |
Your a fucking tool. just shut up.
#21 |
#23 |
#25 |
Admin Asshole
![]() Join Date: Mar 2002
bwalker, pull your head out of your ass and learn what a Mod looks like. No need to bump this thread just to talk shit.
This is over. ![]()
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
