Old 07-15-2007, 04:27 PM   #1
Mlogue84
Mlogue84's Avatar
Mlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfection
Send a message via AIM to Mlogue84
Power steering Lines!! (which ones?)
Ok, so recently i've decided that muscleing my way through turns is not fun. So i've decided to get powersteering for my SR'd S13. The only problem is that lines are hard to find under $200. So i've found these and thought they might be a good idea as well as a good investment, the only problem is that one is like $65 dollars more than the other. I was wondering if anyone has used either one of these, or has any inside info on why which one is better?
So here are the contestants:
(the driftday one is on that page, it's just with some other stuff)
http://www.mamsparts.com/
http://driftday.com/frames.htm
-Mark
Mlogue84 is offline   Reply With Quote
Old 07-15-2007, 04:47 PM   #2
ohspizzill
ohspizzill is on the path to ruinohspizzill is on the path to ruin
both look nice, i would go with the one that dose not have the huge mark up. IMO i think the mamsparts and the DD are the same one just cost more cuz its blue with anaodized fittings.
ohspizzill is offline   Reply With Quote
Old 07-15-2007, 08:22 PM   #3
projectRDM
projectRDM's Avatar
$140 for just the high pressure line is fucking retarded, no matter how pretty it is. You can buy a replacement line from Advance auto for about $65, but then you'll still need the cooling line, return hose, and the reservoir.
And FYI, I had the local Aeroquip retailer make me a high pressure hose deleting the pressure switch because it looks cleaner IMO for $23 by using the OE line's fittings and brazing them on to new fittings.
FORMERLY R240NA
Old 07-15-2007, 09:01 PM   #4
seiran
seiran's Avatar
seiran can only hope to improve
MA's line is awesome.. just put one on my SR... go with that...
seiran is offline   Reply With Quote
Old 07-16-2007, 04:44 PM   #5
n240sxfnatic
n240sxfnatic's Avatar
n240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond repute
This is what I ordered
http://www.club-s12.org/forums/index...66&#entry87566
only around 80-90 dollars
n240sxfnatic is offline   Reply With Quote
Old 07-16-2007, 04:56 PM   #6
brainfood
brainfood's Avatar
Trader Rating: (18)
brainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond repute
Feedback Score: 18 reviews
Been interested in putting some -an lines together with a cooler and everything. Is the inlet and outlet sizes the same on 200sx and s13/s14 racks? Thats what I didnt know but looks like they are:
1 -6AN to 14MMx1.5 adapter (RUS-670520)
2 -6AN to 16MMx1.5 adapter (RUS-670530)
Good info! thanks
Bryan Rogers
http://www.seriousbadass.com
brainfood is offline   Reply With Quote
Old 07-16-2007, 05:02 PM   #7
n240sxfnatic
I was told that they were, also if ur goin that way summit is sold out of the 6' line until the 24th so mine wont even go out until then
Old 07-16-2007, 06:16 PM   #8
Mlogue84
Mlogue84's Avatar
That is some awesome feedback guys, Thank you all very much!
Old 07-16-2007, 06:32 PM   #9
brainfood
brainfood's Avatar
Trader Rating: (18)
I am still putting the kit together on paper. But I will be redoing the whole system with an aftermarket resevoir and a cooler.
Bryan Rogers
Old 07-16-2007, 06:57 PM   #10
Edgar
Edgar's Avatar
Edgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfection
Send a message via AIM to Edgar
http://www.zilvia.net/f/showthread.php?t=149557
Drift Indy
Edgar is offline   Reply With Quote
Old 07-16-2007, 07:08 PM   #11
n240sxfnatic
Ill hit you up when i get it about the rack
Old 07-18-2007, 12:08 AM   #12
brainfood
brainfood's Avatar
Trader Rating: (18)
Just ordered my lines for the high pressure side from summit. I went with russel powersteering lines, they are braided steel and made for this purpose and I can cut to lengther so they will work out perfect. running -6 on the high pressure side. Probably weld a -10 bung to the pump supply and run all stainless lines in the future and a canton baffled resevoir and a powersteering cooler. But for now this will get my s13 powersteering working.
Bryan Rogers
Old 07-31-2007, 03:40 PM   #13
n240sxfnatic
just installed all my lines from summit, they all fit the rack and now i have powersteering post pics tonite
Old 07-31-2007, 04:31 PM   #14
brainfood
brainfood's Avatar
Trader Rating: (18)
my low pressure side was 16x1.5 my high pressure side was 14x1.5 I think my s14 is this way also so I am not sure.
Bryan Rogers
Old 07-31-2007, 08:16 PM   #15
n240sxfnatic
yea thats what i ordered in that link i posted
Old 07-31-2007, 10:29 PM   #16
n240sxfnatic
Old 07-31-2007, 10:41 PM   #17
Dousan_PG
Dousan_PG's Avatar
its real easy
here's a partial pic of my setup
i got it mostly thru sumiit but the PS line thru MA motorsports
here's the reservior i use .
http://www.allstarperformance.com/product.htm?prod=759
i use -8 on the return though!
ill get full pics later
if u want the part numbres and stuff let me know, i can get my invoice from summit for the PS rack
it was real easy
(ps reservour is mounted in stock spot area) ucan see the hsoes there
fittings i think i used
4 -6 90 degree
2 -8 45 degree
2 rack adapters (1 was w/ the ma motorsports setup)
the hp was 2 90 degree (ma motorsports included)
and pump fitting (ma motorsports included)
garage works welded the -8 on my return for ps pump.
Aaron
Pink GodziRa
Old 07-31-2007, 11:41 PM   #18
brainfood
brainfood's Avatar
Trader Rating: (18)
Originally Posted by Dousan_PG View Post
its real easy
Looks clean Aaron, what is the part number for that cooler and how much was it? I have my high pressure side done and am just using heavy duty rubber hose for the low pressure side right now since I was too cheap to buy the resevoir and cooler when I am not even driving the car yet
edit: found it on summits site.
http://store.summitracing.com/partde...5&autoview=sku
Bryan Rogers
Old 08-01-2007, 12:01 AM   #19
Dousan_PG
Dousan_PG's Avatar
yeah thats the one!
my setup was totally around 400some
its pricey but over the weekend it felt awesome
no overflowing now!
its those damn an fittings! SO EXPENSIVE like 15-25 bucks for some!!
at least its not -10 like the oil cooler! they were something around 25/fitting! UGH!!
Aaron
Pink GodziRa
Old 08-10-2007, 06:43 PM   #20
The ROMAN
The ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to behold
Could there be any issues with boiling the ps fluid without the cooler because of the shorter lines? I ordered just the lines from summit since I kinked the high pressure line when I took it off. I know the low pressure line goes all over the place for cooling purposes, would it be better to just leave it till I get a cooler?
The ROMAN is offline   Reply With Quote
Old 08-10-2007, 06:52 PM   #21
brainfood
brainfood's Avatar
Trader Rating: (18)
I think alot of the boiling over problem isnt nescesarily boiling over but the shitty stock resevoir. I finished up the s13 setup did -an all through but used barbed adapters on the low pressure side and some double lined fuel hose for now. Since I havnt ordered a cooler yet. But I have the line and just need to order the fittings and the cooler to do the low pressure side. Since it will be a while since that car is tracked I didnt want to spend the money right now. But I def. think a higher capacity resevoir with the corect baffling will be way better than stock and stop the spilling problem almost everyone has.
Bryan Rogers
Old 09-07-2007, 02:46 AM   #22
Inland180
Inland180's Avatar
Inland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant future
Send a message via AIM to Inland180
So if you decide to add a PS fluid cooler like dousan..... would the oem cooling loop still be needed?? Or would it be fine with out it since it has the big cooler in the front??
PTE6262 Full-Race Twin Scroll FTW!
Feedback LINK
Inland180 is offline   Reply With Quote
Old 09-07-2007, 09:39 AM   #23
Dousan_PG
Dousan_PG's Avatar
i got rid of the loop! useless!
the loop is the stock cooler
Aaron
Pink GodziRa
