Old 08-18-2007, 02:36 PM   #1
Iceman00
Iceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymore
What motor was in the car at the time you weighed it?
* > Drifting
JWT powered Altima
Iceman00 is offline   Reply With Quote
Old 08-19-2007, 01:44 AM   #2
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
Hello Im wondering the same. Because my car is kinda the same , & Im not that light. Is the silvia face that much lighter than pop ups,I have removed the motors too. Anyhow Im just interested cause thats my ideal goal 2220-2250
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 08-19-2007, 01:07 PM   #3
KA24DESOneThree
KA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfection
KA with intake. Still have all smog-legal parts in place, factory manifold, 3" cat to 3" aluminized mild steel piping to Magnaflow muffler.
Also running 245/40R17 RE01Rs on CE/TE combo.
Switching from heavy Optima or stock-sized battery to a Braille will almost guarantee you at least 20lbs weight savings.
I have both bumper supports.
Here's a nearly complete list of what's been removed or replaced to save weight:
-all interior panels except door panels and dash, no glovebox, head unit, headliner, or center console
-rear seats
-most of the sound deadening except on rear wheelwells and driver's and passenger's footwells ahead of cross bar thing
-AC compressor, compressor bracket, condensor, condensor fan, and most of the lines
-replaced Optima with Braille B14115 and relocated to behind passenger seat
-replaced stock power belts with S14 manual belts
-removed stock power sunroof and riveted sheet aluminum in its place
-replaced stock trunk lid with carbon trunk lid, held shut by 2 pins and 2 latches
-replaced stock hood with FG hood, held shut by 4 pins
-removed cruise control
-removed all speakers
-removed antenna
-removed all unnecessary wiring inside the passenger compartment and currently working my way forward
-lightweight flywheel (it's not much but it counts)
-removed clutch fan
-replaced driver's seat with Sparco Pro2000
-USDM front end replaced with Silvia front end
-removed e-brake assembly (necessitated by braking upgrade)
-removed spare (I live life on the EDGE! )
-removed all unnecessary bracketry
-removed wheel well liners
-removed flux capacitor
Here's where I've added weight:
-wheel/tire combo (despite the CEs/TEs each being 3/2lbs, respectively, lighter than stock, the much bigger tire increases the weight)
-front DC Sports strut tower brace
-Nams shakitto plates
-Ultra Racing fender braces
-Nismo TC bracket brace
-Koyo radiator
-Whiteline sways
-SPL subframe and rear link braces
-all the rear links
-aftermarket FLCAs
-coilovers with camber plates
-VLSD diff cover
I'm sure I forgot a couple things but that's about it.
KA24DESOneThree is offline   Reply With Quote
