Old 08-22-2007, 01:22 AM   #1
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Yup, it'll work fine. The only reason to run one, however, is if you intend to buy the consult cable or connector that lets you utilize the factory consult capabilities of the stanza ecu. There's really no point to use it, otherwise. Also, the address files for the u12 are different from the s13 fyi.
Alex
e1_griego is offline   Reply With Quote
Old 08-22-2007, 12:11 PM   #2
LongGrain
LongGrain's Avatar
Alex
i dont know what consult is? and i also dont know what the address files for the U12 means either. its a reprogrammable chipped ecu. its tuned right now to add 10hp to a stock KA, changed timing, a/f maps etc, and raised rev limiter. i plan to run this map until i finish turboing and then reprogram it. should i buy it? or should i buy the one for the 240sx KA24E. what are the advantages/disadvantages. does the stanza ECU have the same maps as the 240? plug and play?
LongGrain is offline   Reply With Quote
