acceleration bogging, help
So the problem is..
When driving normally, my car idles, and accelerates pretty much normal. but when i get on the gas a little, when it hits around 25-3k it stops accelerating all together, but if i lift off and hit the gas again, its normal. could it be maf? 02? i have no idea i searched, but nothing was very helpful. im omw to get a new fuel filter to see if thats it, but if that isnt, im fresh out. Any help would be great!! ]Thanks all 9tb |
![]() Join Date: Apr 2007
i have the same exact problem....
except i have a kae and no mods but exhaust. and my idle just drops way down low like 300ish at random times. i too searched and i found that it could be EGR, which is why my check engine light is on, IACV, MAF, and other stuff. but yeah any other further help is good also. |
maf is a possibility, but i doubt it seeing as it idles, and accelerates normally aside from when i floor it, but my buddy is coming over in a little bit, and im gonna borrow his to see if it is the maf, but has anyone else on here had this problem?
![]() Join Date: Aug 2006
egr (exhaust gas return) simply stated takes exhaust gasses from well the exhaust and reroutes them back through the engine to lower emissions. If i happen to be wrong please correct me
i think i found the problem... the timing marks are way off (btdc), i think i need to remove the distributor line it up to tdc, the put in the teeth correctly. ill get on with the results!
runs much better! timing was it, but i have another question... my car came with an unorthodox racing crank pulley, and the fan belt always squeeks, so do i need to get a smaller belt? the ps pump is as tight as it gets!
#15 |
![]() Join Date: May 2005
i would like to say MAF, this has been discussed many times before. search for how to repair the MAF, it takes a total of 15-20 min max, eliminate the easy variables first
![]() parking lot pimpin... Seller Feedback here: http://www.zilvia.net/f/showthread.p...ight=pbcstylez |
#16 | |
not giving a fuck
Trader Rating: (104)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 104 reviews
so it was ur crank that was marked rwrong?!....so how did u find TDC, the ghetto crewdriver in sparkplug hole trick??? :-) cuz my shit is bogging disgusting to the point that i have to keep my foot on the gas at idle or itll drop revs and die... gonna try TPS i just got...if thats not it, im looking into rebuilding my Intake manifold... since from what ive read in so many f*cking forums... that most of the situation is there... I.E. injectors, EGR, Vaccume leak, TPS/TB,FPR, knock sensor etc... thats my last choice...ive checked every damn plug, leak tested compression tested... this is ultimate ![]() ![]() |
#17 |
not giving a fuck
Ok ladies and gents times for some updates
as i said before i and my mech did a air leak test and plugged up a line... so last night me an him for around 2 hours decided to test censors galore final findings temp sensor (red tip) is good even did what nissan FSM recomends and dipped it in boiling water with thermometer... spark plugs: have what my mech called ''blow by'' and had a white ish tip, which he stated means running lean... injectors: proper voltage on all four and there all spraying properly...my mech even used a stethescope to hear them and were good MAf: voltage is good aswell grounds: good there timing: right on the money stock setting, weve tried advancing and retarding the f**king thing but nothing + out of that compression tested: its at Front: 190 190 190 178: rear, which isnt too bad EGR: got the ebay steel block off and removed EGR assembly...and that actually made the car run worst to the point that i would start it and it would die after 5-10 seconds of being on... we moved the idle control (adjuster on the rear right side of the engine...) and that did help much... so we tried combination of TPS and idle control movement still blah changed the TPS today and still blah |
