Old 10-16-2002, 08:42 AM   #2
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (luke91 @ Oct. 16 2002,12:32)</td></tr><tr><td id="QUOTE">Are there any larger diameter MAFS's out there that could be used on an S13 SR20 without any major modification (ECU reprogramming, S-AFC, etc...)?
Thanks
--luke</td></tr></table><span id='postcolor'>
No.
With the Cobra, Z32, Q45, J30, etc. MAFS, you need to "trick" the ECU at the very least.
Something to consider: &nbsp;The flow restriction of the stock MAFS (what I'm assuming you're worried about) is not that bad. &nbsp;It's about a 2" hole and it only lasts for about an inch. &nbsp;After that, the piping is much bigger. &nbsp;This will have almost zero effect on your rwhp. &nbsp;The main reason for changing the MAFS is to accomodate more fuel and more range (stock MAFS can't read past the flow of air needed for about 275 rwhp).
Eric
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
