Old 08-27-2007, 06:20 PM   #1
bamaboy
bamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfection
removed valve cover, what's this????
I just took Exitspeed's valve cover off to replace the gaskets and we found this. Anyone got an idea as to what this is?
The really shiny piece looks to me like what used to be a timing chain guide. There was a worn spot on the valve cover too. It looks to me like the timing chain was loose and wore a spot on the valve cover. Your help is appreciated.
Right now you are my biggest fan. You are to me what a sex tape is to Paris Hilton, not the best publicity in the world, but at least I'm on people's mind and it has something to do with a pussy!!! HAAHAAAAAAA
bamaboy is offline   Reply With Quote
Old 08-27-2007, 06:24 PM   #2
RazoE
RazoE will become famous soon enoughRazoE will become famous soon enoughRazoE will become famous soon enoughRazoE will become famous soon enough
Send a message via AIM to RazoE Send a message via Yahoo to RazoE
timing chain guide...
get rid of it, even Nissan recommends it...
my KA used to rattle because of it...
SupraMan!!/1986.5 Sports Package/1989 TURBO/1992 HT/2005 Scion xB
RazoE is offline   Reply With Quote
Old 08-27-2007, 06:26 PM   #3
w0nderbr3ad
Trader Rating: (50)
w0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to all
Feedback Score: 50 reviews
Send a message via AIM to w0nderbr3ad
yea its from the chain guide. If the guide was there before then make sure its not in your engine anymore or just drop the oil pan and see if anything else has dropped in there.
w0nderbr3ad is offline   Reply With Quote
Old 08-27-2007, 06:28 PM   #4
bamaboy
cool. It was already out we just wanted to make sure because neither of us had taken our valve covers off before.+ rep to both of you guys from me and exitspeed.
Old 08-27-2007, 06:37 PM   #5
MURPHY
MURPHY's Avatar
MURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfection
Send a message via AIM to MURPHY
^^ agreed. DEFIANTLY drop your oil pan to make sure it's in there. or well maybe someone removed it before. hard to tell but are they just like sitting there or stuck on?
MURPHY is offline   Reply With Quote
Old 08-27-2007, 08:05 PM   #6
Gjohnson7
Gjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura about
My coupe looks exactly like that, except when I removed the valve cover the guide was sitting there, just laying on top of the chain broken in half.
LSX Kouki Project, swap completed in Dec 09
Gjohnson7 is offline   Reply With Quote
Old 08-27-2007, 08:08 PM   #7
Tearlessj
Tearlessj's Avatar
Same here. Just remove it, its a very common issue.
Tearlessj is offline   Reply With Quote
Old 08-27-2007, 08:49 PM   #8
Lith
Lith will become famous soon enoughLith will become famous soon enoughLith will become famous soon enoughLith will become famous soon enoughLith will become famous soon enough
Send a message via ICQ to Lith Send a message via AIM to Lith Send a message via MSN to Lith Send a message via Yahoo to Lith
while you are removing the top chain guide, you could also check your upper tensioner (half the time they are seized and don't keep the chain nice and tight). I think it's about 70-80 bucks for a new one at Nissan.
However, you do need to remove the front cover that houses the distributer. To do that, you have to set your 1st cylinder on TDC.. mark where the distributer was and then remove it. Then you'll have enough room to get to the tensioner and also the side chain guide. The side chain guide some people also remove and/or replace.
Anyways, here's a pic of what I'm talking about:
And here's a full guide to how to do this:
http://www.nicoclub.com/articles.php?id=105618
Lith is offline   Reply With Quote
Old 08-28-2007, 08:37 AM   #9
exitspeed
aWingThing.com
exitspeed's Avatar
I believe that it was removed in the past. i can tell the engine has had a lot of work maintenance wise in the past.
thanks for your responses and posi rep has been handed out accordingly.
