Dyno Results - SR Big28 Power FC
Went for a dyno pull this weekend and thought I'd share as people are always interested in seeing dyno sheets. The dyno was done over at JER in Westminster - Linh who did my pull was really friendly/knowledgeable.
Stats on the car: 1990 240sx SE - S13 Blacktop SR20det - FP Big28 turbo - HKS actuator - Power FC d-jetro - CP pistons 9:1 - Eagle rods - Tomei Poncams - RAS - 650cc DW Injectors - Walbro fuel pump - Apexi 1.1 head gasket - Hybrid FMIC - K&N style intake - 3" DP/CS 3" Exhaust - SS Auto Manifold - Freddy intake manifold - Perrin MBC - XS ignition amp ![]() The dyno was done on a dyno dynamic. The first pull was the best netting 303hp - after that something was acting funny and started losing power even after a cool down. You can see the boost was dropping off quite a bit towards the end - time for a EBC. I'll start diagnosing once I get the datalogit in. The car was spitting up quite a bit of oil through the BOV making me worry that it may be rings or turbo that's going. enjoy. |
I believe its the same turbo they use on the DSM version. I think they pulled the big28 off the Nissan section as they just introduced a new turbo. On their website, in the DSM section, you should still be able to find it.
#10 | |
+1 for JER
hope to see you at the yearly bbq Quote:
with all the info. |
Yeah, check out the regional Cali thread - they have a special going on until Nov for $50 for 3 pulls. Real cool guys and helpful - I will be going back once I get everything sorted out.
Hey nice numbers, I was just there this Saturday getting some things check out on my car. Some guy working there told me there was a blue 240 that did 300 at wheels I guess it must have been yours. I am also thinking of getting the apex power FC D-Jetro for my car and thinking of going with the garret 2871R.
![]() Join Date: Oct 2006
i used to run the FP big28 - it was good to me but i got tired of it fast and sold it to my buddy for his sentra. its hard to upgrade to something like that and stick with it.
are you running a catchcan/breather to intake pipe?
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
#14 |
I just did 390 whp yesterday on dynodynamics at 17 psi on 91 oct.
AFR is still like 10:1 its a great dyno, usually 16% lower readout than dynojet. ...are you sure he didnt have something corrected on the first run, then fixed it and the second two are actually your legit numbers? just a thought... because thats a screen shot and not a printout we cant see what parameters were input. either way decent numbers for that dyno
Like Me on FaceBook ![]() |
#15 | |
No correction from the first run - he wasn't quite sure why the last runs were lower. I actually upped the boost a lil on the last run and still made same numbers. |
#16 |
maybe the missing part is me tuning it haha
cheers man. youll get there. you pulled your revs out pretty high I see for peak I think I stopped at 7300 on mine power was still climbing. -what duration cams? 256?
#17 | |
The cams are mild - yep, 256. |
#18 |
So I got the Datalogit installed and I happen to notice that one of the settings, ignition vs. airtemp, showed that at 50C it would retard ign. by 3 degrees. Could 3 degrees be enough to lose 18rwhp?
That brings me to another question - I recently moved the air temp sensor from the intake piping into the manifold. When it was in the piping, the temp was in the ambient-40s, in the manifold, it ranges 40s-60s. In the manifold is where Apexi suggest although it seems like the manifold is absorbing a lot of heat. Just idling for a prolong amount of time on a cool day is enough to raise it over 50. On a warm day it will go over 60. The piping on the cold side is still cool to the touch, so the air is actually much cooler than the temp sensor indicates. Is this normal and is there any adverse effects to raising the ign retard setting to 60 or 70? |
