Originally Posted by mtx450
Any resolution to this? My car just started these same symptoms tonight. It drives sort of fine at regular throttle, and then when full throttle is applied, or more then 25%, it sounds exactly the same as it did in that video. I also noticed that the EGR isn't moving with throttle anymore, like it used to. That could be it, but then again, the car has already had injector issues. Gonna do some testing tomorrow.
Originally Posted by 240sxScores
yea id like to know what happened to this too. I have a bad idle untill the car is finally warmed up but then theres a jerking in the engine when im at cruising speed in the car that makes the hole car jerk, it gets really damn annoying.
Heh, sorry I didn't post back. I figured out what it was. Very weird actually.
I painted my VC and then replaced the gasket (obviously) and put the VC back on. I then tried that shitty engine cleaner (didn't really work, needs elbow grease) and then hosed everything down. I covered a lot of stuff up, but didn't (idiot) cover up anything by the spark plug wires. Water got into the top of the spark plug and caused no spark. I just took out the plugs and cleaned them and it went back to normal.
