Old 10-17-2007, 01:28 PM   #1
Slowrolla97
Slowrolla97's Avatar
Slowrolla97 is an unknown quantity at this point
Send a message via AIM to Slowrolla97
Weird problem,,,,
Ok this isnt a huge problem i think but it is making me think.
Ok when I hit boost hard my temp gauge will go up to the next bar and then back down. It will only go up for a sec or 2. So what does this mean?? I was thinking my water pump was going out or my belt is slipping. Or I just need a better gauge. What do yall think...
Edit: s13 hatch with s13 black top sr if that means anything
Slowrolla97 is offline   Reply With Quote
Old 10-17-2007, 01:37 PM   #2
S13Leprechaun
S13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant future
well what kinda gauge you using right now? myabe it cant hadle the boost..?
thurs. knights.
S13Leprechaun is offline   Reply With Quote
Old 10-17-2007, 01:41 PM   #3
Koopa Troopa
Koopa Troopa's Avatar
Koopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfection
Send a message via AIM to Koopa Troopa
I think your guage is shorting
Buy my Stillway shifter!
Koopa Troopa is offline   Reply With Quote
Old 10-17-2007, 01:44 PM   #4
S13Leprechaun
or you wired it into your tach.. haha.. jk.
thurs. knights.
Old 10-17-2007, 02:44 PM   #5
Slowrolla97
Naw it is the OEM temp gauge. I heard they are really shitty.
Old 10-17-2007, 03:59 PM   #6
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
they ARE crappy, but it could also be the belt, or the pump cavitating...
chances are its your gauge though..
This is my clever and witty signature.
daryl337 is offline   Reply With Quote
Old 10-17-2007, 04:11 PM   #7
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
your voltage regulator in thhe alt. may not be working properly causing voltage to spike at high rpm. use a multi-meter and check voltage at different rpm. are you sure this is boost related or does it accur at high rpm at idle?
RedtopTech is offline   Reply With Quote
Old 10-17-2007, 05:27 PM   #8
Slowrolla97
Havnt checked. I will be back in 10 minutes
Old 10-18-2007, 09:51 PM   #9
Slowrolla97
I revvd it once and it didnt do it. I have also noticed it will not do it in 1st gear. This is weird.
Old 10-19-2007, 04:32 PM   #10
Slowrolla97
HUmm still no luck.
