#31 |
The Q45 front brakes generate more torque than the 300zx fronts but to me that just says its making an already overly front biased set up even worse. Just throwing the biggest brakes you can find on the front of your car is not going to make it stop any better.
If your only going autocrossing I think you're better off with stock brakes, good pads and good fluid. You are not going to overheat your brakes on an autocross course. Remove the stock proportioning valve and get an adjustable one to dial in the brake bias how you want it (I don't know if that would be legal for your class). An adjustable proportioning valve is probably ~$40. |
#34 | |
![]() Join Date: Jun 2003
the looks was a factor, but not the main reason i got them. weight, caliper stiffness, and pedal feel were bigger factors. it's also a reason i didn't go with a flashier, better big brake kit (aside from overkill). i love that it has the raised nissan on the caliper, but i'm a nerd like that.
#36 | |
![]() Join Date: Jul 2003
not that THAT matters to alotta people |
#37 | |
![]() Join Date: Feb 2007
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
p.s. who does that anyways (runs huge ass front brake and keeps the rears stock)..lol thats retarded If it were up to me I like to run 12" rotors in the front with Z32 30mm calipers and the stock 11.5" z32 rears but im stuck with teh 12.76" fronts for now |
#39 |
![]() Join Date: Oct 2003
I don't know if that math is right for the Q45 scenario...there is probably a huge reason why nissan did not elect to use these on their high line sports/gt cars though.
Personally if it's coming down to Q45 vx 300ZX is make or break a setup, then one should be looking at Brembo class calipers anyway. I am running R33 GTS-T (296x30mm/297x18mm).
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master. |
#40 | |
Trader Rating: (40)
curb weight: Z32 ~3300 lbs (2 seater) Z32 ~3550 lbs (2+2) Q45 ~4034 lbs |
#42 | |
Sorry if I missunderstood. |
#43 |
actually there are a ton of people only swapping fronts. Some say it's because that's how the Silvia top models were done, others due to cost and some due to not feeling comfortable doing the rears (which while not hard is a process requiring large tools many don't have and cable issues).
I did the R33 GTST front and rear. The brakes work and feel great. A couple issues the Q45 setup suffers from is sliding calipers aren't as direct and modulation is more difficult, pad selection (although it has improved with many doing these swaps), and rotor availability. The critical thing most really overlook is the tires. They do up these big brake swaps and go cheap on rubber.
#44 |
did we ever come up with an explanation why s14/s14 silvias got 3Z 30mm fronts but stock s14 rears?
Was it: 1. the s-chassis has different weight distribution from a Z or 2. the BMC is different and corrects the problem or 3. other |
#48 |
In regards to the Silvia getting only fronts.
For one most of the braking is done by the front, it also allowed for no redesign in the rear which would require more extensive setup on the assembly line. Even the stock 240sx brakes are decent enough for many with just a track pad.
#49 |
so running q45s up front and upgrading the bmc is not necesary? or if you were to run q45s up front and stock rears which size bmc would you run the 15/16, 1, 17/16 or just keep it (7/8) stock?
#50 |
![]() Join Date: Aug 2005
Trader Rating: (60)
![]() Feedback Score: 60 reviews
its actually best to keep the stock master cylinder when upgrading the q45 front with stock rears. The brake pedal feel is pretty incredible. I have had both the q45 and 300zx/skyline calipers and I cant tell much difference. It may be different on the track though.
#51 |
![]() Join Date: Aug 2004
+1 For Q45's. I just set my car up with them, rebuilt the calipers, got some brembo blanks, hawk hps and speed bleeders. And it made for a very quick and easy upgrade with great stopping power.
![]() Pushing 14.7 PSI of all natural boost!!! |
#52 |
![]() Join Date: Sep 2007
Running Q45's right now in the fronts w/ dimpled/slotted rotors, and Hawk pads. The rears are simply stock w/ Hawk pads. The only complaint was experiencing rear brake fade after a little over two hours at the Balcony (and this happened only once when my diff blew, and I was just yanking the ebrake)... But that doesn't really answer your question. It only tells you that I thought the Q45s were the better option for my slightly-tracked stock S13.
I guess you really have to look at what you're going to be doing with your car. If you're just daily driving without lots of power, why spend the extra cash? It's not too much more expensive, I know.. but at least you wouldn't have to worry about wheels clearing your calipers. |
#53 |
![]() Join Date: Oct 2006
i remember this thread - so everyone knows porterfield, hawk, endless all make pads for q45/j30 brakes
![]() and yes the feel is good with stock bmc and q front and stock rear. its not like the z front - where u get the brakes lockin up all the time. ill never go back to z brakes - wilwoods yes... that i'd like.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
#54 |
![]() Join Date: Oct 2005
you keep the stock bmc. it is what i run and have no problems. although the aluminum caliper looks cool when parked, it would be pretty hrd to see it when i drift by you.
TEAM SUS*PECT |
#56 |
Good stuff.
Just a quick question, for street use I just have my stock brakes but every once in a while when someone that didnt pay attention because of; eating in the car/talking on the phone/applying makeup etc etc causes me to have to stand on my brakes there are times that it seems my stocks didnt get the job done quite as quick as they could've and I cant help but think that this close call wasnt necessary if I could just upgrade my brake set up properly. So for the best stopping power in SoCal street use what do you guys recommend? (including pads, fluids, lines...anything that might help) Dont mean to jack a thread or sound like I'm repeating the question, but once again, no track use, just street.
#58 |
if its street use, just get fresh parts
new OEM pads, new blank rotors, new fluid (valvoline) no need for anything more than that to roll around the streets, he even said it |
#59 | |
Trader Rating: (40)
#1 Q45/J30 all around or #2 Z33 Front rotors (ofcourse you need adapter bracket with Z32 calipers) and Z32 rear Either if these two setup will knock the socks off of a stock s chassis brake setup and not be dangerous and have the correct front to rear brake torque/bias to not let you get into trouble like the Z32 setup all around will. But your results will vary on Z32's all around based on weather you run a staggered wheel setup (have more grip in the rear) or have more weight in the rear of yoru car, somehting that keep the rear planted to teh ground like a 200lb sand bag will help a bit as well as a full tank of gas at all times...lol. |
#60 |
Why would Z32's all around "get you in trouble" ?
