Old 05-04-2007, 03:24 AM   #1
Behind Horizon
Behind Horizon will become famous soon enoughBehind Horizon will become famous soon enoughBehind Horizon will become famous soon enoughBehind Horizon will become famous soon enough
Rear S15 Crossmember vs. S13 Crossmember
Hello guys,
it seems to be common to swap the original rear S13 subframe and install an S15 one in Japan.
Which are the benefits of the S15 crossmember over the S13 and why shops in Japan do this ?
My opinion is if you put the parts stated below on each subframe, both will perform nearly identical, or am i wrong ?
- Kazama Upper (Camber) and Toe Control Arms Kit
- Kazama Rear Traction Rods S13
- Good Sway Bars
- Aluminium Subframe Bushings
- Polyurethan bushings for knuckles
Looking forward for replys.
Greets
BH
Behind Horizon is offline   Reply With Quote
Old 05-04-2007, 01:38 PM   #2
PoorMans180SX
PoorMans180SX's Avatar
you might want to edit that so it says rear subframe, because that's what it's called, not a cross member.
Old 05-04-2007, 04:28 PM   #3
CKAMC
CKAMC's Avatar
CKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfection
Originally Posted by chmercer
dousan had it on his old hatch like forever ago
using s13 arms
the reason people swap s15 frame is the placement of the pickup points gives a better toe curve
he also put on s14 foward links and s14 toe links
wider track(sticks out an extra 10mm's) and the way it sits(suspension geometry) and what chmercer said are what/why people do the swap...
internet 9th hand also says it allows you to lower the rear even more, especially with large wheels (18's and larger)
CKAMC is offline   Reply With Quote
Old 05-04-2007, 05:00 PM   #4
MadScientist
MadScientist's Avatar
MadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really nice
Sub-Frame swaps are actually fun... you will learn everything on the first time.
S13 is smaller - S14/15 are larger by about (10mm) - S15 has additional strucural supports.
Peace
Drew
Follow on IG - KoukiTheToolBox
MadScientist is offline   Reply With Quote
Old 05-05-2007, 03:37 AM   #5
articdragon192
articdragon192's Avatar
I wonder if I can fit an S15 subframe into my z32. Hmmm...
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 05-05-2007, 07:42 AM   #6
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
I also think is because the S15 has more anti-squat. mounting points on the subframe are like 1-2inches lower on the LCA. Helps control fishtailing coming around corners.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 05-05-2007, 07:52 AM   #7
krappy
Trader Rating: (41)
krappy is an unknown quantity at this point
Feedback Score: 41 reviews
1-2inches lower compared to s13s? or s14s?
krappy is offline   Reply With Quote
Old 05-05-2007, 01:35 PM   #8
CKAMC
CKAMC's Avatar
^^s13
messagelngth
Old 05-06-2007, 02:40 AM   #9
McRussellPants
It has less anti-squat.
It has a better toe curve than S14
Its 10mm wider
the arms are reinforced
If someone could get me Yanack stuff and people didn't charge rediculous amounts of money for S15 stuff just because its off an S15 I'd have one by now.
McRussellPants is offline   Reply With Quote
Old 05-06-2007, 03:11 AM   #10
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
Its 10mm wider
What is toe curve?
Old 10-19-2007, 11:20 PM   #11
flytwa78
flytwa78's Avatar
flytwa78 will become famous soon enoughflytwa78 will become famous soon enoughflytwa78 will become famous soon enoughflytwa78 will become famous soon enough
So I guess if we have an S14, we can make better with an S15 subframe too.
flytwa78 is offline   Reply With Quote
Old 10-19-2007, 11:27 PM   #12
Dousan_PG
Dousan_PG's Avatar
yeah offset bushings are PRICEY!!
i had the subframe as said above
it was cool
Aaron
Pink GodziRa
