Old 10-24-2007, 09:24 AM   #1
fromxtor
fromxtor's Avatar
fromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfection
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
Originally Posted by WilloW View Post
Nice! ^^ Are those just off the shelf Konis, or did you have anything done to them?
Off the shelf S13 drop ins
Originally Posted by tearlessj View Post
Pics of that set-up on car?
They are not on the car yet, thus the "off the car" pictures.
I still need to get around to ordering the GC coils and rear koni shocks. I will be ordering 400/350 springs w/ the GCs.
Seller feedback>>http://www.zilvia.net/f/showthread.p...light=fromxtor
fromxtor is offline   Reply With Quote
Old 10-24-2007, 10:13 AM   #2
Wiisass
Wiisass's Avatar
Wiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond repute
Send a message via AIM to Wiisass
Originally Posted by fromxtor View Post
8611 Double Adjustable
So how are you holding the shocks in the housing? I thought the 8611 was meant to work with a gland nut on the top.
What rear shocks are you using? Yellows, like AceinHole? Or something else?
And to the other guy that posted, why would you need ground controls with Motons, that makes no sense at all.
TIP Engineering
R/T Tuning
Drift and RWD Sport
DriftAssNation
Wiisass is offline   Reply With Quote
Old 10-24-2007, 01:59 PM   #3
McCoy
McCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of light
agreed, I also spy a large bolt on the bottom of his housing holding the strut in from the bottom, this tells me it's an off the shelf koni yellow.
I have a setup almost identical to PJ (aceinhole) with the exception of the 8610 RACE insert, these do require custom housings, especially if you want to gain back some inner tire clearance on the S13 chassis.
For the rear, I'll be reusing the koni yellow with GC hardware for the time being, but will switch over to an 8610 in a custom housing to work with a Z32 rear upright.
Here is what mine looks like currently... still waiting on the rest of my GC order to show up. I'll be running some 550lb springs up front and 400lb springs in the rear.
Where the glan nut is threaded into the top to secure the insert into the housings.
McCoy is offline   Reply With Quote
