Old 10-24-2007, 07:47 AM   #1
djcobra
djcobra's Avatar
djcobra is making a name for him/her selfdjcobra is making a name for him/her selfdjcobra is making a name for him/her self
s14 S14 GT28RS Dyno Results
Hey Guys,
I just had my car dyno'd a few days ago, my goal was to make a good/quick responsive turbo street car. Please see the mods below:
S14 SR20DET Kouki Motor
GT28RS Turbo
HKS Step 2 Cams 256in/264ex
HKS Step 2 Valve Springs
HKS RAS
HKS 555cc Injectors
Peak Performance Retainers
Apexi Metal Head Gasket 1.1mm
Z32 MAF
Apexi Power FC
Tomei Expreme Exhaust Manifold
Tomei Expreme Elbow
GReddy Down Pipe 3"
Test Pipe 3"
Stock Bottom End Motor.
Car was on the DynoJet and she put down 303 rwhp and 293 rwtq, with only 14-15 psi boost on 92 pump gas. (we're also at a higher elevation level, Calgary, Canada).
I was expecting a little higher, around the 320 whp range... My question is are these numbers normal? or should i expect a little more out of this setup?
Thanks,
Steve.
djcobra is offline   Reply With Quote
Old 10-24-2007, 08:28 AM   #2
jobestudios
jobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the rough
Is it a .64 or .86 a/r?
Either way, the gt2871r guys you see making 400 whp are on 20+ psi You have a slightly thicker headgasket, turn the boost up to 18 psi. I might have went with a 264/264 cam setup.
-Jackson.Vaughn.Photography-
jobestudios is offline   Reply With Quote
Old 10-24-2007, 08:33 AM   #3
mayco_86
mayco_86's Avatar
mayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfection
It probably should had been a little higher power wise but not bad still. Throw in some higher ocatane bump up the boost and see what type of numbers you will get with that.
mayco_86 is offline   Reply With Quote
Old 10-24-2007, 09:54 AM   #4
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
I made 330hp on a dyno dynamics
S13 sr stock bottom end, fresh head (new everything)
gt28rs @ 15psi
hks step 1 264
freddy intake mani
tomei expreme
enthalpy tune
greddy pulleys
Unorthodox crank pulley
spec flywheel
1 piece aluminum driveshaft
Couldnt hold 18psi to redline, boost kept dropping off, but you can see it made about 20 more tq and the power came on a bit faster in the midrange.
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 10-24-2007, 10:12 AM   #5
usdm180sx
usdm180sx's Avatar
He has the gt28rs not the 2871r.
-Norm!
Old 10-24-2007, 03:44 PM   #6
slideways2004
slideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enough
Send a message via AIM to slideways2004
yeah gt28rs is different. i think that's a good number especially at higher altitudes.
slideways2004 is offline   Reply With Quote
Old 10-24-2007, 04:02 PM   #7
vipi0
vipi0 is an unknown quantity at this point
Send a message via AIM to vipi0
but the rs is supposed to be a better turbo than the r WTF?!?!?!?
vipi0 is offline   Reply With Quote
Old 10-24-2007, 04:04 PM   #8
steve shadows
steve shadows's Avatar
how so?
you guys are all buying into a lot of marketing
the turbo is half the picture
the EMS is the other half
Like Me on FaceBook !
Old 10-24-2007, 05:47 PM   #9
usdm180sx
usdm180sx's Avatar
2871r has more potential than the 28r.
-Norm!
Old 10-24-2007, 07:52 PM   #10
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Get JWT Ecu and S3 cams
Make 330-340 at the same boost.
Other than that, good stuff. I love the Spud.
Old 10-24-2007, 09:32 PM   #11
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
28rs is same as an s15 turbo yes? s15 turbo's i've seen 280rwhp consistently at about 17-18psi, so the head flow because of the cams is probably what put you over 300. sounds about right to me. 28/71r is a bit better but don't upgrade to that if you're not satisfied, go 30r is my advice. i think you did pretty well man. to be honest....300rwhp feels the same as 400. and 300rwhp you should be in the mid 12's. go pwn a rich guy in a viper hahah. congrats man =]
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 10-24-2007, 11:06 PM   #12
mizono
mizono is making a name for him/her selfmizono is making a name for him/her selfmizono is making a name for him/her self
Dave
the gt28rs isn't the same as the s15 turbo, the gt28rs is the disco potato or some shit. The gt28r is the s15 turbo, and its limitations are around 280-300whp approx 16-18 psi max. How do you figure 300hp feels the same as 400hp?
mizono is offline   Reply With Quote
Old 10-24-2007, 11:09 PM   #13
EJ253
EJ253's Avatar
EJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfection
Send a message via AIM to EJ253 Send a message via MSN to EJ253
those numbers are decent.
in utah we usually get worse numbers too
elevation ftl
maybe up the boost
The gap between MORE and ENOUGH never closes.
DriftUtah | UtahNissans | MySpace | I <3 Drifting. Keep it Real.
Secret Society
EJ253 is offline   Reply With Quote
Old 10-25-2007, 12:13 AM   #14
McRussellPants
Torque is dropping like a stone.
and I geuss it doesn't like boosting 18 because it looks like its dropping back to 15.
That turbo looks not too great
McRussellPants is offline   Reply With Quote
Old 10-25-2007, 03:41 AM   #15
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
I dont knwo about going from Power Fc to JWT..thats a down grade...
anyways... who tuned your Power FC?
is it fine tuned?
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline   Reply With Quote
Old 10-25-2007, 04:27 AM   #16
smelly240
smelly240's Avatar
gt28rs (disco potato) wont really make over 325-330 thats its limit.
its considerably smaller than a 2871R - its a 2860RS - s15 turbo is a little smaller - 2861R
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 10-25-2007, 07:46 AM   #17
statik
statik's Avatar
The turbo is awesome if you dont want over ~340hp and ridiculous spool up. It holds 18psi fine with a proper wg/controller.
Old 10-25-2007, 08:28 AM   #18
mayco_86
mayco_86's Avatar
Dave
I agree with you. He should just go with the 30r like that he can be satisfied with the horsepower range.
Old 10-25-2007, 10:42 AM   #19
djcobra
djcobra's Avatar
Hey Guys,
thanks for all the postive input, I just wish I hit the nice 310-320 whp number. I double checked my boost control setup and it was set at 14.5 psi. Mind you I do have a thicker head gasket (lower'd compression a little) which allows me to increase boost a little more **safely. Statik, i'm impressed with your numbers, just wish I could attain the same whp at 15 psi. Then again this is just a GT28RS turbo (spud), which I really like. I'll try increasing the boost upto 16-17 psi and see how she does on the dyno which i'll do next year. I'm parking the car during the winter anyways; Calgary has some harsh winters.
The car was tuned with Apexi Power FC by a really good tuner here in Calgary who is also a legit HKS pro dealer/tuner, we used the Power FC Data Logger and Software/Laptop (which belongs to a friend of mine).
I'll post up my Dyno chart later tonight for you guys to view, hopefully get more postive feedback.
Steve O.
Old 10-25-2007, 11:34 AM   #20
steve shadows
elevation ftl
maybe up the boost
thats what a weather station and Baro-Correction are for.
If he were at sea level the read out might even be lower on the dyno.
If you guys are in Cali have a power fc or want a haltech, I can tune your shit like this all day sideways
here is lukes car we just did with a straigth
50 trim/t4
264 cams stock bottom end,
PB mani,
Haltech E8 Plug and Play
STOCK intake manifold and TB
38mm wg
PWR FMIC
91 octane piss
12 psi of boost
Old 10-25-2007, 09:49 PM   #21
Z U L8R
Z U L8R's Avatar
it doesn't feel much different to me. simple as that. when finally made 300, i thought to myself "this feels fast as shit" then i got used to it. so i upgraded the turbo, made 441 "this feels fast as shit" then got used to it. so again i'm upgrading the turbo. this process may never end but as i said. 300 doesn't feel that different from 400.
Old 10-25-2007, 10:09 PM   #22
djcobra
djcobra's Avatar
Hey Guys,
here's the Dyno chart, sorry for the delay...
Old 10-25-2007, 10:12 PM   #23
codyace
codyace's Avatar
Trader Rating: (58)
is it fine tuned?
Pffft. I'm make more power than anyone with similar setup. JWT woot.
Nada. Plenty of people making over that. Buddy of mine running 18 psi on a B14 makes 360whp/330 ft lbs, on a pretty much mild engine (JWT ECU, MSd 50lbers, Cobra MAF, JWT S3 cams, GTiR manifold...
Exactly. If you want a uber fun street tire smoker, get the GT28RS They are awesome on prett ymuch anything!
Old 10-26-2007, 12:11 AM   #24
GabeS14
GabeS14's Avatar
Originally Posted by codyace View Post
Pffft. I'm make more power than anyone with similar setup. JWT woot. They are awesome on prett ymuch anything!
Lol, i have JWT S14 tune/850cc inj/Z32 maf/ and when i put in the Power Fc with mild/ basically base tune. its faster.JWT runs very rich too.
but good ifyou dont have enough cash to get a standalone and cover the tunning too.
(JWT is very expensive for the little involved in their basic tune)
Old 10-26-2007, 01:36 AM   #25
fro20
fro20 is making a name for him/her selffro20 is making a name for him/her self
You will never get codyace to back down on the JWT thing, I am going enthalpy on my gti-r motor with the spud and s3m cams and some ~550cc inj. we'll see codyace. It will take time though
fro20 is offline   Reply With Quote
Old 10-26-2007, 03:37 AM   #26
GabeS14
GabeS14's Avatar
what does Enthalpy put in to their tunning?
same as JWT? is it a daughter board?
pop charger??
lol..
Old 10-26-2007, 05:11 AM   #27
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
i dont know what it is to you but i hit 210whp at 7psi on an s15 gt28r. making over 300 at 18-20psi should be no problem. this was on my CA too.
ch1873857 is offline   Reply With Quote
Old 10-26-2007, 06:11 AM   #28
Z U L8R
Z U L8R's Avatar
my friend insany on tuesday,bone stock s13 sr20det with gt28/71r = 220rwhp@ 4 psi...
looking at your graph @ djcobra your turbo starts spoolin hard at 3k, but hits full boost @ 4k....says it's 2 cents, then walks out the door at 4800, by the time you hit 6800, all the fun is over. hmmm
http://i214.photobucket.com/albums/c...U_L8R/dyno.jpg
my RB25 , gt30/71r red = 13-14psi, blue = 20psi 93 octane 3.54 diff, pink = old tune 4.11 diff
gt30/71r on a 2.5L /w stock head/cams @ 13-14psi powerfc vs
28rs on a 2.0L @ 14-15 safc2 ....close comparison or no? in regards to turbo lag, overall powerband , etc
i will say though, being able to adjust timing definately helps. safc is ok, but powerband kicks ass with stand alone. there are things like safc2 or a generic "this is my mods i'll send u my ecu, you tune it, i'll put it back in the car" that will get you by, but if you want the most out of your car's potential, stand alone is where it's at. and once you know what you want, and know your power goal, spending money on a good turbo is well worth it. just my .02
Dave =]
Old 10-26-2007, 10:06 AM   #29
codyace
codyace's Avatar
Trader Rating: (58)
Lol, i have JWT S14 tune/850cc inj/Z32 maf/ and when i put in the Power Fc with mild/ basically base tune. its faster.JWT is very rich too.
Did you dyno the two? Did you drag race the two to compare ET/Trap speed?
Then you don't know if it was faster. JWT has an 850cc program? I think I may need to call them about that, when I get my water injection and launch control questions answerd as well (Oh yea, sorry, my lame JWT has both those options as well).
Money's not an issue, trust me. I went with what would be better for a daily driven, daily beat on, HPDE, Drag race turbo car. I've been in Standalone cars. They may make MORE hp, but IMO at the cost of some of nice drivability that the stock ECU provides. I'm not building a race car, so no need for race car parts.
And, as with all JWT ECU's, you can simply datalog a run, send the information out to JWT, and they'll gladly mail you a new chip for you to install (while at the same time returning your old one).
It's always easier to bash something you're ignorant about. Has JWT ever blown up a car either?
And sorry, Power Fc isn't much better IMO as a standalone. Haltech, etc etc is a standalone.
Hehe. Enthalpy is in the same boat as my thoughts on JWT. It's a well designed and setup rom tone program, from one of the SR20 leaders. I prefer JWT, however always ALSO suggest RS Enthalpy when it comes to new people getting ECU/Rom TUnes.
pop charger??
lol..
Pop chargers are noted for making HP on N/A cars. Dyno proven. Going to continue?
Tuning? It's a daughter board and rom tune. Both shops have spent countless hours dyno testing, creating parts, dynoing again, building motors etc etc, and are confident enough to release a rom tune. They are all MAF cars, so it's not rocket science to get them to work.
Old 10-27-2007, 03:45 AM   #30
GabeS14
GabeS14's Avatar
[=codyace;1611023]
#1Did you dyno the two? Did you drag race the two to compare ET/Trap speed?
#2JWT has an 850cc program? I think I may need to call them about that,
#3
#4
Pop chargers are noted for making HP on N/A cars. Dyno proven. Going to continue?=QUOTE]
question#1
yes I also did do some street pulls, (no dyno) and its obvious, i know how fast my car feels, and when plugging in a new computer, all of a sudden my car is faster, hmm...maybe it makes sense to say it runs better with the new one???
dont need to be a tech to tell the difference.
question#2
they took my injector did a flow test and made a program for me. cost $30 to flow test,and another $700+ or- for tune.
question#3
but yes JWt was the cause for my engine being blown, ..according to 2 different shops, it was running too rich/knocking
question #4...lol... if you read my post I stated"LOL" which = it was a joke.
i just named that because JWT offeres that on their website so maybe they did too,
I do hear a lot of good things about enthalpy though.
You are right about making changes on curent tune setup,(even though they do charge $100)
anyways,
i didnt say they were shit, i said i prefered the power fc, as most people on the forum too,
