Old 12-09-2001, 01:00 AM   #1
gwong
gwong is an unknown quantity at this point
Can't seem to figure out why my engine is overheating all of a sudden.  I'm ruling out a bad head gasket because the motor oil is okay, and no smoke from my exhaust.  Compression seems fine.  I replaced my stock radiator with a new 2 row, changed thermostats twice, flushed the system, and I'm still overheating under hard boost.
gwong is offline   Reply With Quote
Old 12-10-2001, 08:11 AM   #2
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
How much boost are you running at the time your engine overheats? How good is your intercooler?
S13Grl is offline   Reply With Quote
Old 12-10-2001, 08:24 AM   #3
ca18guy
ca18guy's Avatar
ca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfection
more important question would be, what type of engine do you have. Were not mind reader's <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
ca18guy is offline   Reply With Quote
Old 12-10-2001, 08:38 AM   #4
S13Grl
Married to the Mob
S13Grl's Avatar
He's got an SR20DET
Old 12-10-2001, 08:46 AM   #5
Guest
Posts: n/a
muahaha ..... ####...... *dreams* maybe u have some problem in the delivery of the cooling stuff ........ yah <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=';)'>
Old 12-10-2001, 10:08 AM   #6
240sxracer
240sxracer is an unknown quantity at this point
check your hoses &nbsp;mine was overheating because my lower radiator hose was colapsing also check for air in your cooling system our you might have too much antifreeze also did you replace your plugs before it started overheating &nbsp;the wrong gap or plug can cause overheating
240sxracer is offline   Reply With Quote
Old 12-10-2001, 11:16 PM   #7
gwong
Sorry, but I have a turbocharged, rebuilt KA24DE. &nbsp;Only running average 10 psi boost.
Old 12-10-2001, 11:22 PM   #8
gwong
I'm afraid I might have done something internal, like cracked a head or something. &nbsp;So far I've pretty much eliminated every other possibility I can think of. &nbsp;I've tried eliminating and blurping all the air out the system as possible, but it seems like everytime I run hard, the hoses swell up real hard, like more air has entered the system. &nbsp;I hear there's something called a Block Check?? &nbsp;that I can use to test for exhaust gases in the coolant. &nbsp;That may help give me a better clue.
Old 12-11-2001, 02:46 PM   #9
ca18guy
ca18guy's Avatar
Sound's like it might be internal, since you replaced everything in the coolant system. Have you replaced the water pump? Sure you checked all the hose's. Has me scratching my head, post back if you find the answer.
Old 12-11-2001, 04:33 PM   #10
gwong
No I didn't replace the water pump. &nbsp;Should I because I think it's working okay. &nbsp;In the meantime, I'll just keep tinkering around until I hit the problem.
Old 12-11-2001, 08:23 PM   #11
Arcane
Arcane is an unknown quantity at this point
it probably is the water pump...because i just got my car back from a shop because my car was overheating also...my water pump was leaking and i spent like 70 + labor to get it fixed...
Arcane is offline   Reply With Quote
Old 12-11-2001, 08:54 PM   #12
alchemist
alchemist is an unknown quantity at this point
ouch 70 and labor.....that pump is only like 30 remanufactured at napaonline
alchemist is offline   Reply With Quote
Old 12-11-2001, 09:10 PM   #13
Arcane
i don't buy remanufactured parts...the shop won't warranty the part...
