Old 10-20-2007, 10:01 PM   #1
sil80forme
sil80forme's Avatar
sil80forme can only hope to improve
Send a message via AIM to sil80forme
need help. everyone stumped! injectors not priming?
so my problem is that during initial startup the injectors dont prime to start... but if i turn ignition to the on position and take a test light and ground each injector its starts up fine and stays runnin with no problems. i thought it might be an ecu prob but i swapped ecu's and it still does not work. i check all visible grounds and everything looks like it is hooked up correctly. i am using r/c engineering injectors which was stated when i purchased that they were high inpedence so i dont need resisters but if i was told incorrectly what would happen if the injectors were low inpedence.. thanx oh yeah this is a ka
sil80forme is offline   Reply With Quote
Old 10-20-2007, 10:06 PM   #2
MURPHY
MURPHY's Avatar
MURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfection
Send a message via AIM to MURPHY
your ecu is bad. if you have to MANUALLY ground them out most likely your ecu is bad. the ecu should give them ground to feed
MURPHY is offline   Reply With Quote
Old 10-20-2007, 10:07 PM   #3
sil80forme
sil80forme's Avatar
already put a new one in and that didnt solve the prob. its something else
Old 10-20-2007, 10:50 PM   #4
rps13drift
rps13drift's Avatar
rps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfection
If your injectors were indeed low impedence your ecu will eventualy burn out due to it over basicaly over working itself
rps13drift is offline   Reply With Quote
Old 10-22-2007, 03:10 PM   #5
sil80forme
sil80forme's Avatar
how can i tell if the injectors are low inpedence
Old 10-22-2007, 03:34 PM   #6
MegasquirtCA
MegasquirtCA's Avatar
MegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfection
use a multimeter and set it to OHLMS its a omega sign. If its low impedance resistance is usually 4ohms and under. High Imp is usually 10ohms and up
MegasquirtCA is offline   Reply With Quote
Old 10-24-2007, 06:20 AM   #7
sil80forme
sil80forme's Avatar
could my wires on the injector harness where they were spiced in be backwards?
Old 11-06-2007, 10:45 PM   #8
sil80forme
sil80forme's Avatar
well the injectors are 12.4 ohms so they are def high inpedence... anyone else have any other ideas of what it could be.
