![]() Join Date: Jul 2007
Those with Topmount Turbo's and ROM Tune with MAF, Please Help!
I have searched religioulsy locally, so I'm going to expand my search. I'm running a TS 3071R Topmounted with an Enthalpy Rom tune. So, basically I'm still running a MAF. I'm sick to death of Maf turbulence, the car idling like shit, and the car cutting off if I don't manually "catch" the revs. I know this is Mafs turbulence, but I can't lengthen my intake pipe anymore unless I have a custom one made (I can't find ANYBODY locally to do this and I've searched). So, can everybody show me the picks of YOUR Intake Pipe setup with a topmount and Mafs? Or, if somebody knows a shop or can build me a pipe that will fit in my bay with the appropriate length/bends I will gladly pay somebody. Here is a pic for reference followed with my current setup.
![]() Now, my setup at the moment. ![]() |
With "Blow Through" do you mean routing the breather from the Catch can into the intake pipe after the Maf? Will that eliminate my problems?
Also, the poster that put his pipe "down". Did that elimanate the turbulence?? I'm just sick of the horrible idle and such. But, is does run fantastic under full throttle. |
#7 | |
![]() Join Date: Aug 2005
Hmmm. Interesting. So, the Maf would function normally and this would eliminate all of the symptoms I described? Also, I could just bolt the Filter right onto the turbo with no Intake Pipe if I did blow through right?
![]() Join Date: Jun 2004
an SAFC will fix this with the decel setting.
[email protected] |
Probably not, that sounds like you tps or timing, or AICV or TUNE is off.
I just know for a fact that one of the little things the SAFC does right is Decel AFM Signal trick, where you lift and the SAFC sends a flat voltage to the ecu for the MAF signal, fixes the Open atmosphere BOV dip and and turbulent maf air. Unfortunately the SAFC doesn't make for a good tuning tool.
[email protected] |
#14 | |
#15 | |
I've checked TPS voltage, my base timing is 15* and my tune is Enthalpy, and I DOUBT his tune is off. I've had 4 tunes from him with all spot on AFR and such. I have not checked the IACV, but it does not seem like a problem related to that. So, from what I'm reading, a blow through setup would be the easiest way to rid all of these problems? Or, get a custom intake Pipe? |
#16 |
Do you have a picture of this setup? I've looked the engine bay over, I just don't see anywhere to extend this to unless I have a custom Intake Pipe made with several bends. I've already purchased the Aluminum pipe, I just cant find ANYBODY willing to custom make one for me.
#17 |
![]() Join Date: Feb 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
yea i had my maf to close and it was doing the samething you are talking about, my car would foul a set of plugs in less than 5 minutes, then i extended the pipe and it ran fine.
you, its whats for dinner. |
#20 |
To avoid this on a turbo KA setup, we ran the filter in the driver side front fenderwell area with the MAF shortly after it and a longer pipe going to the turbo. Seemed to work pretty well. BUT, then you have all the issues associated with a CAI, namely sucking up water if you go through puddles, etc. Could be hard to route depending on your IC setup also.
#21 |
flatter filter (like the hks... or ebay knockoff anyone?), and longer pipe, push it up against the fender well.
[email protected] |
#22 |
Thanks for the suggestion, but that's the step I'm at now. I had the JWT Pop Charger, but then bought an Power Enterprise Filter because of it's compact nature and I have it tucked as deep and as far into against the fender well as I could get it.
#24 |
you're supposed to have at least 12" of piping from the MAF to the compressor wheel, right?
why not just route it down. I've seen some people route the filter infront of the motor.. not a great idea! |
#25 |
True, I've seen setups with the intake on the passenger side. You get a really long straight section of pipe that way, but you have to worry about clearing cold side IC pipes, clutch fan (if you still have it), plus possible heating of the charge air (doubtful). Actually, might not be a bad idea if you have room.
#26 |
![]() Join Date: Mar 2003
you guys that run MAFS on the gt3071 TS should order it with the 3" inlet instead of the 4". that 4"-3" reducer cant be helping the turbulence inside the intake.
#27 |
![]() Join Date: Oct 2006
![]() its downstairs where u cant see it unless ur out front layin on the ground. the extra width opening is for the ported shroud - the compressor wheels inlet is still little... not driven in or around water... - just so u guys know.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
#28 |
Smelly240, thanks for the picture. I'm going to try and figure out something soon. Is there any way you can snap a picture of the actual Mafs and Filter location?? Thanks!
#29 |
Good point on the 4" opening- I wonder if that significantly affects turbulence within the MAF when using a sharp 3"-4" transition coupler. From what I've read about the ported shroud housings, I'm not even so sure I'd want one, but that's besides the point if you already have it on there. I'd say that somehow relocating the filter and MAF to inside your front fenderwell is the way to go. Also try to keep the BOV recirc hose and/or catch can vacuum source far from the MAF is possible.
