Old 11-19-2007, 12:32 PM   #1
DirtyS14
DirtyS14 will become famous soon enoughDirtyS14 will become famous soon enoughDirtyS14 will become famous soon enoughDirtyS14 will become famous soon enoughDirtyS14 will become famous soon enough
Differential (VLSD) Hissing Noise
Yesterday I installed an s13 vlsd from an s13 into my s14. The diff fits in nice and cosy, everything is torqued to factory spec, diff is full with oil. When the car starts moving there's a hissing noise from the back and it gets louder with speed. I only got upto about 30mph before I stopped the car. At 30 its loud enough that you really can't hear someone talking.
I drove with this exact diff in an s13 and it was as quiet as a mouse. I looked under the car and can't see any marks of anything rubbing on anything 'cause that's seriously what it sounds like. The only thing I can think of is this... the s14 has bushings in the front two mounting bolts.. this could hold the front of the diff a little lower... so when i put the s13 (non bushing) setup in, the front of the diff is elevated a little bit causing the diff flange/driveshaft flange to be elevated enough to rub on the body. But thats the thing, I can't see any rub marks on anything in that region.
And yes i've searched like a dog....
Thanks in advance...
Edit: The entire s13 case is in there, I didn't mess around with the internals, just switched the diff covers.
DirtyS14 is offline   Reply With Quote
Old 11-19-2007, 01:14 PM   #2
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
i know the s14 front diff mounting bolts are longer then the s13 bolts. did you put the correct amount of fluid into the diff?
WheelsDirty
Old 11-19-2007, 01:23 PM   #3
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
^^ how much oil did you put in?
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 11-19-2007, 01:45 PM   #4
silnismo
silnismo's Avatar
silnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enough
Maybe somthing fell in the diff while installing.
silnismo is offline   Reply With Quote
Old 11-19-2007, 02:56 PM   #5
DirtyS14
I basically filled it with a syringe until the level came up to the fill nut and it started to overflow... Oh yeah, i used the s13 (shorter) bolts because there are no bushings on the s13 diff. I used 80w-90 GL-5.
Yeah but wouldn't that prove for a clunking, locking, exploding situation? All I have here is a hiss.. but I was super careful to not drop stuff into it.
Thanks for your help/time guys!
