Old 11-20-2007, 08:37 PM   #1
projectRDM
projectRDM's Avatar
Possibly. Anyone can build a driveshaft and balance it on a lathe, but who knows if during shipping it got a ding or knick in it, or if your car just has a shitass drivetrain alignment and nothing balances right. My Enjuku shaft was balanced, but it was still off a bit when I had it rechecked. A quality shop locally welded a weight to it, ground it the welds flat, then rechecked it, it was then dead on. A few grams is all it takes for noise.
FORMERLY R240NA
Old 11-20-2007, 09:31 PM   #2
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
wouldnt the same apply for bad roads???
Old 11-21-2007, 09:22 AM   #3
projectRDM
projectRDM's Avatar
How? The driveshaft spins on a flat plane. Going over a bump doesn't change the plane it's spinning on since the whole car moves, or at least the drivetrain does. The subframe moving (or the diff) within it's mounts could cause a cross load on the shaft, but not enough to unbalance it.
Think of like a washing machine. The barrel spins freely when unloaded. When loaded, all the clothes dissipate evenly and keep the barrel spinning on an even path. If something becomes lodged though and shifts all the clothes to one side, the barrel begins to rotate off axis, thus making noise. even if you put the washing machine on an uneven surface, the barrel finds a way to center itself when loaded.
FORMERLY R240NA
Old 11-21-2007, 09:46 AM   #4
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
wow i like the washer explanation thank you
Old 11-21-2007, 10:04 AM   #5
unicoladron
unicoladron's Avatar
unicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choices
lol!! the washing machine in my apartment has this sensor that will stop the washing machine when it detects it's off balance to a certain degree. it usually happens if you do a very light load, which just tends to stick to one side of the machine during the spin cycle.
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving
unicoladron is offline   Reply With Quote
