Old 11-22-2007, 04:32 PM   #1
Nolmack
Nolmack is on the path to ruinNolmack is on the path to ruinNolmack is on the path to ruin
installed the new mounts last nite.....
I still have have the spring catching on the perch locks ( this only occurs during sharp turns like such as making a left turn at a light)... but i have no more memory steer. BTW i also lubed the pillow mount with some grease idk if that helped a bit.
Nolmack is offline   Reply With Quote
Old 11-22-2007, 11:31 PM   #2
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
Installed mine last night. Everything seems to be moving smoother. Bit easier to adjust height. I too lubricated the pillowballs before I put them in. Lets see how it holds up.
some documentation pics:
old mounts:
new mounts:
compare the two (new left, old right):
The top circle area where the pillowball mounts to appears redesigned. Mount is also now slightly thicker.
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
Old 04-30-2008, 11:05 AM   #3
cxlo8331
Location: Feasting on the flesh of the guilty, and drinking the blood of the innocent (714)
cxlo8331 is close to perfectioncxlo8331 is close to perfectioncxlo8331 is close to perfectioncxlo8331 is close to perfectioncxlo8331 is close to perfectioncxlo8331 is close to perfectioncxlo8331 is close to perfectioncxlo8331 is close to perfectioncxlo8331 is close to perfectioncxlo8331 is close to perfectioncxlo8331 is close to perfection
ok, so here's an update:
intsalled new pillow ball mounts yesterday and got an alignment.
Amazingly, the noise is gone and no memory steer. the new mounts are like the ones DAPCWIZ posted up:
Originally Posted by DaPCWiz View Post
new mounts:
My old mounts were black though.
Everything seems to be working great. car rides butter smooth now.
Hopefully this problem is solved. I'll keep my fingers crossed and will update if anything goes wrong.
-Carlo
cxlo8331 is offline   Reply With Quote
