Old 11-29-2007, 09:22 PM   #11
.:JD240:.
.:JD240:. is an unknown quantity at this point
Pin 1 - for now don't connect this pin.
Pin 2 - connect this pin to ground to be safe.
Pin 3 - connect this pin to the Black/White and Black/Yellow wires on the ignition switch harness.
Pin 4 - connect this pin to the White wire on the ignition switch harness.
Ok i'll try this tomarrow, but if black and whit and black and yellow are connected won't the car crank anytime the key is in the on position?
Shouldn't it be black/white and white on the same connector? and black/yellow on it's own since that's what I'm trying to send the power too?
Thanks for all the help, i really appreciate it
.:JD240:. is offline   Reply With Quote
