Old 12-01-2007, 02:07 AM   #1
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
Clutch Fan Problems, car sounds like a bigrig(fan)
So my 240sx sounds like a dam bigrig when rpms increase.
The noise is from the fan.
I thought the clutch fan was bad so i bought a new one, and it still does the same thing.
I searched and it said that its *not spose to Spin when the motor is Cold.
Right now as it is, the fan spins hard when i do a cold start.
Anyone got ideas?
importdude is offline   Reply With Quote
Old 12-01-2007, 02:09 AM   #2
Dousan_PG
Dousan_PG's Avatar
the fan is hookeed up to your water pump
which belt is to the crank
which means it will always spin
wow
please dont touch another car in your life.
Aaron
Pink GodziRa
Old 12-01-2007, 02:11 AM   #3
importdude
importdude's Avatar
LOL,
the thing is it was never this loud
btw the clutch fan is not a solid peice connected to the water pump
just b/c its bolted to it doesnt mean it has to spin all the time
the clutch fan is 2peices and there is a bearing inside
just asking for help, no need to be jackass
Old 12-01-2007, 02:25 AM   #4
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
wait, did you just buy another fan?(the plastic part?) or a fan CLUTCH (the metal part that the fan attaches to).
Old 12-01-2007, 02:26 AM   #5
SiI40sx
SiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfection
Send a message via AIM to SiI40sx
Does your car overheat when your stopped? When the clutch goes out it does make a louder noise. You sure you replaced the correct part???
SiI40sx is offline   Reply With Quote
Old 12-01-2007, 02:27 AM   #6
importdude
importdude's Avatar
i replaced only the clutch fan(metal) no the fan itself
car does not overheat
i got the new clutch fan from carquest
Old 12-01-2007, 11:18 AM   #7
aznpoopy
aznpoopy's Avatar
alright
#1 the fan is supposed to spin when its cold. it'll just spin less.
#2 it has a viscous clutch, not a bearing. there's fluid inside that locks up as it gets hotter, just like a vlsd.
#3 when the s14 fan dies, it locks up all the time. so the car won't overheat regardless (unlike a rx-7 clutch fan). if its real bad, it'll make belt squeal from the fan trying to spin at high rpms with the engine.
#4 imo just get another one from the junkyard. i don't know what carquest is but the replacement you got was probably generic and is therefore not working well.
Old 12-01-2007, 04:53 PM   #8
importdude
importdude's Avatar
Carquest is a Big parts chain,
i can get another one no problem,
i guess thats what ill be trying,
another new clutch fan
Old 12-01-2007, 05:05 PM   #9
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
or you could ditch the clutch fan all together and buy dual altima fans for about $50 at the junkyard, and wire that up to run when the ignition is on.
I did that after my clutch fan snapped the studs holding it on the water pump and had to tow my car back home because it was late and I couldn't see shit in my engine bay (the fan actually disconnected some wires in the process, one was to the distributor)
Old 06-06-2008, 01:44 AM   #10
rajcat
rajcat's Avatar
rajcat is an unknown quantity at this point
i think i have the same problem rite now, just happend a day or too ago. after driving to work and parking, i noticed it sounded different wen i revved it even just a lil before i shut it off.
freaked me out, cus my OEM exhaust just died and was replaced from the cat back, plus pipe infront of cat was replaced, so now im hearing air noise from the front and im freaking out! like wat could possibly be left of the OEM crap thats gonna fall off?? but im seriously lost, was hoping u guys had an answer.
im starting to think maybe sumn is gonna just fall off and the car is gonna get hella loud again lol
the fan is blowin hella hard, but sumone said it culd be thermostat.
rajcat is offline   Reply With Quote
Old 06-06-2008, 02:30 AM   #11
s13_maJiK
s13_maJiK's Avatar
s13_maJiK is an unknown quantity at this point
you would be overheating if that was the case
s13_maJiK is offline   Reply With Quote
Old 06-06-2008, 08:09 AM   #12
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
few questions...does the car run? obviously yes... its loud.. so what! if it aint broke dont fix it lol just drive the damn car im sure the sound will do away as you get used to it lol
i need tires is offline   Reply With Quote
Old 06-06-2008, 03:31 PM   #13
JDM671
JDM671's Avatar
Trader Rating: (37)
JDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to JDM671
my car does the same problem. The fan sound will go away in a few min then it will come back. People in signal auto said its normal. But it gets kinda annoying because my car sounds like a semi truck. lol I bought my fan clutch from autozone sooo idk. O_O
Touke <3
JDM671 is offline   Reply With Quote
Old 06-06-2008, 04:10 PM   #14
undercoverdjay
undercoverdjay is making a name for him/her selfundercoverdjay is making a name for him/her self
Send a message via AIM to undercoverdjay
Originally Posted by aznpoopy View Post
alright
This is your issue. My clutch stuck and it sounded the same way. So much in fact when I stepped on the car, people looked because it sounded like it had a supercharger on it (air wise). Ended up being a little bit of wired from the road wrapped itself around the shaft between the clutch and front engine case and somehow wore it out.
undercoverdjay is offline   Reply With Quote
Old 06-20-2008, 04:36 PM   #15
JDM671
JDM671's Avatar
Trader Rating: (37)
sorry to bring up old threads but. I think I know what you mean. Heres a vid I made for my car.
[ame]http://www.youtube.com/watch?v=3fFWNdcBowU[/ame]
[ame]http://www.youtube.com/watch?v=JQlEiBhWo9A[/ame]
Touke <3
