Old 12-01-2007, 11:40 AM   #11
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
Originally Posted by Ragnarok043 View Post
i remember reading in one of the writes up that the problem is caused by the sensor grounding. you can test by unbolting the sensor while its running, it should stop running at full blast.
Yes, you have to grind down the fins on the thermo sensor. In most cases the fins ground out on a line behind it and cause the blower to run full tilt.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
