Old 12-12-2007, 07:01 PM   #1
Drift N Dragg
Username Monster!
Drift N Dragg's Avatar
Drift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud ofDrift N Dragg has much to be proud of
91 Coupe Speedo Problems
I have read some of the other threads and I have tried what they said.. I have a Digital/Hud Cluster, I swapped it for a Analog and rewired it to everything its suppose to be.. I checked all fuzes (Before swap and after swap) ... I ran a direct line from the VSS to the Cluster.. Nothing..... I Ohm'd out the VSS i was told it should be between 200 - 300.. it ohm'd at 255... I am at a loss.. I have swaped, rewired, multimetered, Ren Direct connects, check fuzes, I do not know what else to do.... Can someone give me any other problems that might cause this?
More so disgusted. Much like how a dog owner reacts when they notice a dog about to eat some shit off the ground because the dog thinks its a good idea.
2015 Subaru STI
1997 Mitsubishi Eclipse GSX
A Ton of Projects
Drift N Dragg is offline   Reply With Quote
Old 12-12-2007, 07:08 PM   #2
nissan240sxkid
nissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enough
did you find that some of the wire colors were off because its sould work when you swap cluster and harness cuz signals are the same
nissan240sxkid is offline   Reply With Quote
Old 12-12-2007, 07:13 PM   #3
Drift N Dragg
Username Monster!
Some were off but Not too many.. most were direct swaps...
2015 Subaru STI
A Ton of Projects
Old 12-12-2007, 07:18 PM   #4
nissan240sxkid
I dont know what the problem is but I have had problems with the wires being slightly off or a pin was in the wrong place......good luck if I can find a answer before someone else I will contact u
Old 12-12-2007, 07:26 PM   #5
Drift N Dragg
Username Monster!
Thanks ... This is getting frustrating.. LOL... cant tell the officer "No Sir, I really dont know how fast I was going" LOL
2015 Subaru STI
A Ton of Projects
Old 12-12-2007, 08:02 PM   #6
2ilvia
2ilvia's Avatar
2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore2ilvia is not welcome here anymore
FYI; you didnt state exactly what the problem is, im guessing it simply doesnt work
since you say everything checks out ok, then the coil could be weirding out on you, or the needles just stuck, try banging on it
2ilvia is offline   Reply With Quote
Old 12-12-2007, 08:20 PM   #7
Drift N Dragg
Username Monster!
Oh sorry, i guess i didnt.. Still no Tach or Speedo.. everything else works
2015 Subaru STI
A Ton of Projects
Old 12-12-2007, 09:00 PM   #8
Drift N Dragg
Username Monster!
I really need my car speed and tach on or no pass smog.. bump bump
2015 Subaru STI
A Ton of Projects
Old 12-12-2007, 10:32 PM   #9
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
why didn;t you just swap the sub harness and call it a day, ive done that shit so many times. its plug and play, take old HUD cluster out with sub harness, put new analog cluster in with sub harness. done.
Review Thread
bardabe is offline   Reply With Quote
Old 12-12-2007, 11:40 PM   #10
Drift N Dragg
Username Monster!
No complete subharness came with it.. it was cut up ... so I only had what I had..I cant just grow a batch of wires, ya know.. LMAO... but If I can find one I would try it
2015 Subaru STI
A Ton of Projects
Old 12-13-2007, 12:43 AM   #11
Drift N Dragg
Username Monster!
Does anyone know or have a pic of the difference between the DOHC Cluster and the SOHC cluster?
2015 Subaru STI
A Ton of Projects
Old 12-13-2007, 01:08 AM   #12
Drift N Dragg
Username Monster!
BUMP for help Bump and a Bump
2015 Subaru STI
A Ton of Projects
Old 12-13-2007, 10:41 AM   #13
bardabe
bardabe's Avatar
teh diference is that the SOHC cluster redlines @ 6.5K and the DOHC redlines @ 7K then obviously the tach singnal for both is diferent. other than that they are the same pin out and speedo. i would say just go to ure local junk yard and find an S13 with an analog cluster. take the sub harness for it its only 4$ and u will
A) make ure car look allot cleaner
B) save yourself a headache
C) won't have to fix it inn the future
D) wont risk burning anything / shorting anything out because of unproper soldering and wraping skillz
OK USA!
Review Thread
Old 12-13-2007, 11:10 AM   #14
burnsauto
burnsauto's Avatar
OK USA!
+1......................
