![]() Join Date: Nov 2007
![]() ok its freezing cold out side you know so cal at nite and at the drive thru and look at my temp guage and see the its running hot got home and checked it radiator full with water and top radiator hose hot and bottom one not and looked for something on here and nothing so help thanks
![]() Join Date: Aug 2007
to check your thermostat just touch the upper radiator hose and bottom radiator hose while its hot...and see if they are the same temperature. if they ARE. then most probably your water pump.....if they are not the same temperature...then your thermostat is shot
#7 | |
![]() Join Date: May 2005
Get a Fail-Safe. We sell em at AutoZone and I only hear good things about them.
![]() Quote:
http://zilvia.net/f/sale-items/24807...-stuff-fs.html |
well i drove around today for a good 20 minutes, it didnt over heat at all, stayed in the middle the whole time. parked and felt the hoses, and the bottom one is hot, but the top one is a lil bit hotter, not by much though.
![]() Join Date: Nov 2006
Trader Rating: (54)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 54 reviews
have you done anything to fix the overheating problem though?
sometimes thermostats are finicky and don't always open when they're suppose too (i.e. stopped at a red light). first thing you should do is bleed your system for a good 5-10 min just to be on the safe side. buy another thermostat seeing as they're less than $10 and while your at it a new radiator cap. it's just good ol' preventative maintenance. how long has it been since you've changed your radiator hoses? if you'll be changing your thermostat and see even the slightest of wear on either hose I'd ditch both and get some new ones.
- Jimmy Wanted: TBD For Sale: TBD |
#15 |
hey guys, i put in a new thermostat, jacked the car up from the front, and added coolant and turned the car on without the radiator cap and let it idle, but it wouldnt stop bubbling and coolant started pouring out alot so i turned it off, is it supposed to do this?
#16 |
just drove it around a lil bit and within 10 minutes or the temp started to go up almost to the H again so i parked it, and the lower hose still isnt getting hot.
#20 |
havnt changed the pump, im thinking i didnt bleed it right sence i stopped cuz it was bubbling coolant out during the bleeding process
#24 |
Trader Rating: (54)
screw off, cap off, jacked up front, and for 5-10 min or until you don't see any bubbles coming from the bleeder hole. also, it's not a bad thing to squeeze both top and bottom hoses while doing this, just don't get burned or anything.
#26 |
Trader Rating: (54)
nope. something is f'ed. bad radiator maybe, try it without the thermostat installed and see what the outcome is?
