Old 12-20-2002, 02:59 PM   #1
midnights14
midnights14's Avatar
midnights14 is an unknown quantity at this point
Send a message via AIM to midnights14
Help! :(
I hear this weird noise when I reverse sometimes, and it sounds like a loud rubbing noise, BUT I don't think my tires are rubbing. Also, there are no scuff marks on the insides of my fenders...any ideas as to what this noise could be? (BTW, I only hear the sound when I'm in reverse....)
E-mail: [remove]that240guy[remove]@gmail.com
AIM: TehApologizer
midnights14 is offline   Reply With Quote
Old 12-20-2002, 03:07 PM   #2
Dousan_PG
Dousan_PG's Avatar
check your brake pads (rear) improper wear (it may have been installed incorrectly) can lead to this problem (i had it on my car at one time)
Aaron
Pink GodziRa
Old 12-20-2002, 03:31 PM   #3
mrdirty
mrdirty is an unknown quantity at this point
sounds stupid but look for something under the car that might have got hooked up and dragged. I dragged around a plastic bag for a week...
mrdirty is offline   Reply With Quote
Old 12-20-2002, 05:06 PM   #4
C-Kwik
C-Kwik is an unknown quantity at this point
Send a message via AIM to C-Kwik
You're slider pins on the calipers may be seized. It's tyupically a simple fix. Tear apart the slider pins, remove any build-up, and then add some grease(the auto parts store should have a grease designed for this application).
C-Kwik is offline   Reply With Quote
Old 12-21-2002, 08:40 AM   #5
bbp
bbp's Avatar
bbp is an unknown quantity at this point
check your tc rods. also check your wheels well to see if the plastic liner has come loose.
bbp is offline   Reply With Quote
Old 12-21-2002, 11:33 AM   #6
Joe_M
Joe_M is an unknown quantity at this point
Send a message via AIM to Joe_M
It's the rear brakes. I have this problem now.
Relube the caliper slider pins and reinstall the pads. Problem fixed.
Joe
Joe_M is offline   Reply With Quote
Old 12-21-2002, 02:02 PM   #7
midnights14
Ok, I'm guessing that it has something to do with the brake pads...I think I didn't lube the caliper slider pins....are the pins the ones that hold the caliper in place? I'm not exactly sure what they are....oh, and mrdirty, that's good advice....that was the first thing I looked for when I heard the sound ....I'm pretty sure I installed the pads right, but I'll redo 'em just to make sure.
Thanks you guys! You were all really helpful...I'll let you know what happens...! Thanks again!
AIM: TehApologizer
Old 03-26-2003, 02:57 AM   #8
midnights14
Ok, this is an old topic and I still get the noises....what's weird is that the only time it makes noise is if I go from D to reverse...meaning it doesn't make a noise when I back out of the garage from park. And the noise is coming from my rear right wheel...it sounds like a very loud rubbing noise, but not like tires rubbing....
AIM: TehApologizer
