Old 01-01-2008, 06:59 PM   #1
TOMKAIRA93
TOMKAIRA93 is making a name for him/her selfTOMKAIRA93 is making a name for him/her self
SR: Ran out of gas, now my car is crap!
Alright, here's how it went. First off, my car fuel gauge doesn't work, neither does the low in gas light. I hardly use the 240, but yesterday I was planning on installing new rear speakers so I was headed to my brother in law's house and that's when I ran out of gas, on my way over. Well, put gas in the tank (twice just to make sure) and the car would not stay at idle. It would at times crank up and idle for like 5 seconds and die back down. Well, after a few hours of this ordeal, we decided to tow the car back home (about .5 miles, luckily). Today, we tried again. At first, the car would idle for more than 10 seconds but die back down. We then unplugged the AFM and TPS and tried it that way, well, guess what? the car would crank up and stay at idle, but once we connect the AFM it would die again, same with the TPS.
The weird thing is that it would turn on without these two things connected, but when either or is plugged back in, the car would die.
I've searched regarding this, but no luck. If anyone has gone through this before, please post comments of how you corrected the problem. Thanks!
Happy new year!
TOMKAIRA93 is offline   Reply With Quote
Old 01-01-2008, 07:08 PM   #2
PoorMans180SX
PoorMans180SX's Avatar
Running out of gas is terrible on the fuel pump. You probably damaged it permanently.
Old 01-01-2008, 07:13 PM   #3
genericforumname
Location: Florida, where we prove that shit does in fact run down hill
genericforumname is making a name for him/her selfgenericforumname is making a name for him/her self
the walbro fuel pumps can be damaged when you let your fuel tank get below 1/4 of a tank since they are physically smaller than the stock units, I dont know what the damage entails but that might be the problem
genericforumname is offline   Reply With Quote
Old 01-01-2008, 07:16 PM   #4
ThatGuy
Admin Asshole
ThatGuy's Avatar
Fuel lubricates your fuel pump, and keeps it cool.
Old 01-01-2008, 07:38 PM   #5
TOMKAIRA93
I do have a walbro pump. So, how is it that the car idles fine when the TPS and AFM are unplugged? This is the part am not getting. If someone can explain, I'd appreciate it. Either way, I will try to exchange my fuel pump tomorrow to see how that goes. Thank folks!
Old 01-01-2008, 08:05 PM   #6
amplifi3d
amplifi3d is making his/her stupidity well-knownamplifi3d is making his/her stupidity well-knownamplifi3d is making his/her stupidity well-knownamplifi3d is making his/her stupidity well-knownamplifi3d is making his/her stupidity well-known
change the maf
amplifi3d is offline   Reply With Quote
Old 01-01-2008, 08:06 PM   #7
TOMKAIRA93
why should I change the MAF?
Old 01-01-2008, 08:19 PM   #8
smelly240
smelly240's Avatar
yeah - its not like running outta fuel ruined the maf and tps -
I suggest being sure its got a full tank, unhook batt for a bit, hook back up and then click to on and listen for the whir of the fuel pump priming up. If you cant hear it - walbros are loud - theres something wrong there. Also u should be able to hear it while th ecar is running.
i dunno about the tps and maf... maybe in limp mode the car does something different with the fuel pump???
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 01-01-2008, 08:34 PM   #9
TOMKAIRA93
I know I could hear the fuel pump priming, but am still going to exchange it to see what happens. I'll put more gas in it, too, just to see. I did put around 5 gallons after I ran out.
Old 01-01-2008, 08:53 PM   #10
TOYTECH1
TOYTECH1 can only hope to improve
You sure it initially ran out of gas?
TOYTECH1 is offline   Reply With Quote
Old 01-01-2008, 08:59 PM   #11
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
^^^ True that, could have been your fuel pump that fucked up first and not the actual running out of fuel.
Old 01-01-2008, 10:48 PM   #12
Doluck
Doluck is on the path to ruinDoluck is on the path to ruinDoluck is on the path to ruin
I would start with the maf, then the tps... I dont think its a fuel issue or ot woudlnt start over and over, after a few starts it would run out of gas in the lines. Its something else..
Doluck is offline   Reply With Quote
Old 01-01-2008, 10:55 PM   #13
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
sounds like you have shitty MAF, try changing it out
Old 01-01-2008, 11:24 PM   #14
derk
derk is making a name for him/her selfderk is making a name for him/her self
sounds exactly like the problem i had when i had a huge vaccume leak (read: blew off a intercooler coupler)
derk is offline   Reply With Quote
Old 01-01-2008, 11:58 PM   #15
murda-c
murda-c's Avatar
wouldn't that be a boost leak?
Old 01-02-2008, 08:12 AM   #16
CylonFrakker
CylonFrakker's Avatar
CylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond repute
Send a message via AIM to CylonFrakker
make sure you also check your FPR to make sure your not leaking any fuel in to the vacuum line..
UGR.....SOMETHING WICKED THIS WAY COMES....
CylonFrakker is offline   Reply With Quote
Old 01-02-2008, 08:24 AM   #17
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
My bet is that u have a vacuum leak and u didnt run out of gas. Double check all ur hoses and pipes first
Old 01-02-2008, 08:30 AM   #18
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
Also: If you did indeed run out of gas, I'd change your fuel filter once you get things straightened out. When you run the tank dry like that, it has a way of sucking shit up from the bottom of the tank and clogging the fuel filter. At least, my 88 Celica had a way of doing that, I must have changed the fuel filter like 5 times over ~40,000 miles.
I probably should have just kept the tank full
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 01-02-2008, 08:38 AM   #19
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
fuel pump clogged, gas tanks rust from inside, could be clogged up.
also fuel filter, maybe clogged.
you should change the pump anyway, you should have a upgraded pump
and get a z32 fuel filter.
If running out of fuel is your issue, these should fix it!
gl
Russ
sillyvia13 is offline   Reply With Quote
Old 01-02-2008, 06:26 PM   #20
TOMKAIRA93
gl
Russ
Well, the fuel pump is new walbro. Probably less than 100 miles on it and the fuel filter is new z32 as well. I don't use this car at all. its been a project for the past year and now is when it started coming along. I just use it to go around the block until I get her body straight. I know what a boost leak feels like and this was no boost leak. I know I ran out of gas. I could hear the fuel pump priming air into the system and no gas. I think I f up the fuel pump and filter. Like many have said, running low in gas will cause the pump to suck up all the junk from the tank. I guess I'll take it as a positive since the car had bad gas in the tank from when I bought it any ways. I will post my results once I replace these parts or test with borrowed ones. Thanks for all the inputs.
Adan
Old 01-02-2008, 10:59 PM   #21
deesz
deesz is making a name for him/her selfdeesz is making a name for him/her self
i would say first off disconnect the battery for at least 15 min to reset everything. next i would say if that dosnt work then it could be a vacuum leak..
what happends when you give it a little gas after its been started to try and keep up the idle enouph to not shut off?
deesz is offline   Reply With Quote
Old 01-03-2008, 10:21 AM   #22
TOMKAIRA93
I tried the battery trick, didn't work. When try giving it gas, it dies down.
Old 01-03-2008, 10:30 AM   #23
SDS13COUPE
SDS13COUPE's Avatar
SDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant future
Are you throwing any codes from the ecu?
SDS13COUPE is offline   Reply With Quote
Old 01-03-2008, 02:38 PM   #24
TOMKAIRA93
nope! Haven't tried that yet.
Old 01-03-2008, 11:37 PM   #25
JDMClifford
JDMClifford's Avatar
JDMClifford is an unknown quantity at this point
What the hell are you thinking! did you think about what you said?
anyways. you could have cloged your injecters, fuel pump strainer, and/or your fuel filter. also you could have overheated your pump. my sugestion is to buy them all at your local parts store and install all of the parts except the injecters and see what it does. and if all else fails pull the injecters and clean them out or send them out to be rebuilt.
Parking lot pimping
JDMClifford is offline   Reply With Quote
Old 01-04-2008, 01:10 AM   #26
SDS13COUPE
SDS13COUPE's Avatar
Check them to see if anything pops up and go from there.
Old 01-06-2008, 03:45 PM   #27
TOMKAIRA93
Well, I finally pulled out the fuel pump and notice the little hose from the pump to the line was damaged. I ended up changing the FP with another walbro I had laying around and obviously a new piece of hose. Turned the key and the car started right up. That's all good, but now I have a boost leak somewhere that doesn't allow me to step on it as it won't rev past 3.5K rpms. as if it had a rev limiter or something. This shit is getting old.
In summary, I never really ran out of gas, although it seemed like it, it was the hose that burst and wasn't holding pressure so the car died every time I'd give it gas.
Thanks for all the inputs guys.
Peace!
Old 01-06-2008, 09:18 PM   #28
Gjohnson7
Gjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura about
Glad to see your fixing some of your issues. Hopefully you'll be back to 100% soon.
LSX Kouki Project, swap completed in Dec 09
Gjohnson7 is offline   Reply With Quote
Old 01-06-2008, 09:36 PM   #29
Sidewayzzz
Sidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura about
Send a message via AIM to Sidewayzzz
sounds like your MAF is disconnected if your not able to rev past 3.5k rpms, did you unplug it during troubleshooting and forget to plug it back in?
Sidewayzzz is offline   Reply With Quote
Old 01-06-2008, 09:55 PM   #30
slow40sx
slow40sx's Avatar
slow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud of
Send a message via AIM to slow40sx
i'm so glad i don't have an SR
slow40sx is offline   Reply With Quote
