Old 01-02-2003, 12:24 PM   #11
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
Originally posted by James
hey Hippo,
Worn pads should be replaced.....
BUT you're speculating the pads are worn.
Topping off may lead to forgetting........
you're speculating this guy is a moron.
Most brake pads squeal........
if you have aftermarket pads I speculate you would be smart enough to check them.
Just stick to the facts:
brake light comes on on corners= low brake fluid
=fill brake fluid.
Not rocket science- and I gave reasons why it's not a big deal.
Now if you want to create more scenarios to make yourself sound smart= you have a complex.
"Keep it simple stupid."
[edit]
There's a reason it's an idiot light and not a gauge - you don't just add fluid willy-nilly to make it go away. The light means check out the system and fix the problem, not fill it and forget it. There are scenarios where a pad won't squeal before bad things happen (e.g., broken tab, no tab, tab bent at installation, seized caliper, etc.), as noted by dousan. Again - a light means investigate not avoid. Now James, for the THIRD time, I ask you to go back and read my first post that mentioned two/2/II reasons fluid would be low and not more - if it isn't the pads, it is a worse problem of a leak.
HippoSleek is offline
