Altima rotors with Q45 calipers
Can I use altima rotors with q45 calipers? I'm having a hard time finding a place that will re-drill rotors. I've had these q45 calipers for a while now, and since they bolt right up and I'll need new rotors and pads anyway, why not?
q45 282mm x 28mm vs. altima 280mm x 22mm Would performance be greatly sacrificed by using this combo? Is it safe? Someone on another board said "the smaller 2mm dia isnt a big deal and 6mm width difference is easily absorbed throu the pad/pistons" |
![]() Join Date: Sep 2005
I was actually thinking the same thing, but just adding a couple shims.
Of course this would be considered _____________! [script]fill in the blank script[/script]
you can use 93-99 altima rotors, with 89-99 maxima calipers, brackets, mounting hardware and pads, the pads will stick off of the rotor by like 1/4 in but it wont hurt your braking or even make any difference
Well someone sent me a IM and said they have been using this setup for 2 years and also autox. He said the only thing he had to do was adjust the brake booster/BMC rod. He adjusted it out just a hair and hasn't had any problems. This is on a s13 non-abs with stock BMC.
how do you adjust the rod? So there are no 4 lug rotors that will work without any adjustment? Is the BMC rod like adjusting the clutch? Anyway, what year altima rotors are the specs you stated?
heavy throttle sells z32 26mm rotors that are redrilled for 4 lug and powder coated for about 150. i installed mine a couple of weeks ago and they work and look great. the pad fits perfect, it doesnt hang over the edge and is within a few mm of the inside. my brakes worked without any adjustments to the bmc, solid pedal and no lock up under hard braking.
#9 | |
yeah if you want i can email you some pics i took with my camera phone when i was doing a test fit. the pics dont show the edges but belive me they work.
#11 | |
I guess the z32 redrilled rotors would be a better match, heat wise. |
#14 |
![]() Join Date: Oct 2006
if you call heavy throttle - they might be able to get you the proper rotors for the q brakes... or see ur local machine shop, or buy a drill bit.
brembo blanks 75$... drill bit 10$... porterfield q45 pads - 80$... its not hard.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
#19 |
![]() Join Date: Dec 2002
Nick, I can drill your rotors. You can nab that overflow bottle too. Hit me up.
#20 | |
I got a overflow already too. Thanks man! |
