lsd identify plese.
ok i have a problem.
i think this is a nismo lsd. lookz similar from the one on courtesy. the problem is its reallie hard to turn. on the ring gear (bigger) it says 43:12? which is the higher one i believe. the thing is its hard to turn. history of it been sitting for awhile. and oil in it is reallie old. and when i cracked it open it dint even have to drain oil out. my 2nd problem i took out the output shafts. and i forgot which side goes in which side and i dont know the tq specs of the brackets. please help. ![]() ![]() ![]() ![]() ![]() ![]()
fS! vlsd ! slim fans ! hid kits ! lug nuts ! http://www.zilvia.net/f/search.php?d...earchuser=bo2o ^^^click^^^ |
ok i found the write up with specs. but i still dotn know which output shaft goes where.
can i just use my 6 bolt shafts? the one thats on it rite now is 5 bolt. and the casing is the vlsd from a 180sx.
think nismo, cause non smooth diff outside, most nismo, trd, mazda speed, lsd have a rough outside, the real aftermarkets, most have smooth outsides
giantroboteyes.wordpress.com/ |
shorter output goes on the left side (driver side)
Sale: Hello Kitty Horn Button S14 Rear Valences K.Y. Gordon the Thief (Tony Chen) |
R.I.P. Aya, always love
![]() Join Date: Nov 2001
Trader Rating: (215)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 215 reviews
thats a 3:58 geared rear end . Very interesting. That rear end ratio was not used in any of the GTR's or S series chassis's. Thats like a Nissan V8 ratio or a Z31 ratio. You better have some real HP coming out of your engine or that ring pinion is going to be a dog off the line. Remember our cars stock have 4:08's.
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html |
![]() Join Date: Dec 2006
If its hard to turn make sure its shimed corectly, I had the same prob when I shipped mine home (I had to break it down) and forgot to lable the shims. once the carrier bearnig journals are tightened you should have a little bit of back lash
it has a lil bit of back lash.
would it be hard to turn because of gearing? its not the 3:58 gearing it says 49:12 or 43:12 cant remember. but ill check it agen.
#9 | |
Otherwise your going to get a different number lol. you divide the larger number by the smaller number for your final drive ratio.
so is it harder to turn if i have the 4:08????\
forshure its the vlsd housing from a jdm s13 it has 5 bolt axles too
Basically LSD's are just a bitch to rotate by hand. lol
