Old 01-12-2008, 04:15 PM   #1
sillydrift
sillydrift's Avatar
sillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond repute
Send a message via AIM to sillydrift
help sparco evo 2 seat mounts
ok so i just got a sparco evo 2 seat, i mounted it in my s14 but im too tall i sit really close to the roof, im 6'1, does any one know whats the lowest seat mount, rail i can use, its a side mount seat, i have searched but i cant come up with a direct answer, thanks for your help
sillydrift is offline   Reply With Quote
Old 01-12-2008, 04:32 PM   #2
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
bride low max rail? very solid very low for most seats.
nams d lock? what kind of seat rail are you using?
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 01-12-2008, 05:33 PM   #3
chuy
chuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura about
If your Evo seat is anything but the basic. Meaning L, XL they wont fit on any of those mounts. I had to make mine custom, since the stock mounts are kinda side and bottom mount.
Slide Happy
chuy is offline   Reply With Quote
Old 01-12-2008, 06:05 PM   #4
sillydrift
sillydrift's Avatar
i have the sparco sliders and base mont thats what im using, but im too tall for it so i took it out
Old 01-12-2008, 10:38 PM   #5
chuy
Mine is "fixed" the only thing mine is the feet to a bracket then the seat. My seat does not slide back.
Slide Happy
Old 01-12-2008, 10:41 PM   #6
nissan240sxkid
nissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enough
Im 6'1" also I used nams super low rails they let me sit the bottom of my sparco evo on the floor of the car alteast the back but part
nissan240sxkid is offline   Reply With Quote
Old 01-12-2008, 10:43 PM   #7
nissan240sxkid
oh forgot have the brides on other seats the nams are lower once you flip the rear seat mount bracket on the rail...thats how I got it to sit on the floor or almost I couldnt fit my pinky under it and the seat still slides
Old 01-12-2008, 10:52 PM   #8
sillydrift
sillydrift's Avatar
which model of nams are you using? i found two diffrent sets, i know the evo2 is wider im just wondering if it will still bolt on to the sides
Old 01-12-2008, 10:59 PM   #9
nissan240sxkid
um I was using the reg evo but the rails or brackets to the seat from rails do move in and out a bit....I think if you had to make a small mod it would still me worth it
Old 01-12-2008, 11:01 PM   #10
sillydrift
sillydrift's Avatar
cool thanks ill try them out
Old 01-12-2008, 11:02 PM   #11
nissan240sxkid
what ever rails dont have the a cross piece that connect to each other so the seat can fit inbetween them instead of on top is the way to go and I never noticed a diff from a platform style rail...
Old 01-12-2008, 11:16 PM   #12
cfinch
cfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond repute
It wont fit in a bride rail by a long shot but if you want to go low you kinda need to use those rails unless you custom fab something... What I do is add tabs on the side closest to the door which mounts them wider and put the seat in. It's slightly off center but not really noticable only problem I have had is you have to move the trunk/gas door latch...
cfinch is offline   Reply With Quote
Old 01-12-2008, 11:22 PM   #13
sillydrift
sillydrift's Avatar
yeah i heard that too, i was going to go with the nams/Nagisa Sidemount Ultra Low Seat Rail, they look like they would fit
Old 01-12-2008, 11:49 PM   #14
THEMkris
THEMkris has a spectacular aura aboutTHEMkris has a spectacular aura aboutTHEMkris has a spectacular aura aboutTHEMkris has a spectacular aura aboutTHEMkris has a spectacular aura aboutTHEMkris has a spectacular aura about
hey bro. use the nams/nagisa rails. thats what i have on my evo right now. they go very low.
THE HAPPY E-BRAKE MONKEYS!
THEMkris is offline   Reply With Quote
Old 01-12-2008, 11:53 PM   #15
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Those probably won't work, but not sure. I have an evo2 that I got with some bride rails, and it didn't fit (not by a long shot). Ended up having a friend make me a fixed bracket that puts the seat *right* along the cat hump...can't get any lower.
I think that's about your only option since the seat is wider than the jdm-sized seats.
Alex
e1_griego is offline   Reply With Quote
Old 01-14-2008, 01:32 PM   #16
sillydrift
sillydrift's Avatar
ok after searching around, and using your guys input im about to order these nagisa rails http://www.frsport.com/Nagisa-Sidemo...SX_p_3003.html any of you guys think i would have problems with the EVO2 seat?
Old 01-14-2008, 01:37 PM   #17
Koopa Troopa
Koopa Troopa's Avatar
Koopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfection
Send a message via AIM to Koopa Troopa
Take a picture of your installed seat so I can tell you what you're doing wrong..
Buy my Stillway shifter!
Koopa Troopa is offline   Reply With Quote
