Old 01-18-2008, 11:42 PM   #31
PhilthyS13
PhilthyS13's Avatar
PhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfection
Originally Posted by kingkilburn View Post
That is a little missleading. Most(try 95%) of the polution in #2-5 comes from LA. The wind blows into the valley and has a hard time finding its way out, hence Bakersfield being number two even though there isn't any thing there.
Yeah, but it's still all CA. It's not like smog blowing up from TJ or from NJ to NY. That's the very reason that those laws were enacted, it has everything to do with LA polluting the surrounding area aka the rest of California. We just have too many people (hence ludicrous real estate prices).
If you live in the middle of nowhere (Trinity), the only time you have to smog is transfer of ownership. So it matters which county you live in.
Lol, you said that Bakersfield is "number two."
PhilthyS13 is offline   Reply With Quote
Old 01-19-2008, 12:18 AM   #32
4thHorse
4thHorse's Avatar
4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice
Is it true that places high north in cali don't smog there cars. I was told places like napa don't have to smog.
4thHorse is offline   Reply With Quote
Old 01-19-2008, 12:35 AM   #33
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
What idiot told you that!!!??? The smog laws are the same for the whole STATE!
Old 01-19-2008, 12:39 AM   #34
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
Same year or newer.
Doesn't have to be same make.
As long as it utilizes all the oem equipment off of the new motor then you're fine.
Truth.
Originally Posted by GSXRJJordan View Post
Like everyone said, the CARB ruling says that a motor swap can only be legalized if the motor being swapped in is smog-legal in the car it came in, and is the same year or newer than the chassis.
Again, truth.
Originally Posted by StaticX27 View Post
Not entirely true. You can swap a motor from the same chassis (such as a honda getting a B16 instead of a D16) without needing a ref's approval. However, you can drop a motor from any car into a US chassis as long as you have the approval from your local referee, thereby getting a BAR sticker.
WRONG. You can't *legally* pass smog in say, a '92 Civic Si hatch with a B16 in it, even if its a 100% stock motor from a '99 Si coupe, UNLESS IT IS BAR-APPROVED. ANYTIME you swap ANY motor than is not the OEM engine for that particular year, it needs to be ref-approved. Even KA-E to KA-DE swaps need BAR-approval to be legal.
Also, you can't swap any motor into any car... The engine has to come out of a car that is the same year or newer.
Get your facts straight before spreading false information, please.
Why not go to a state ref and say "Hi, I've got this and I want to do this. What do you need to make this a BAR legal swap?"
That, however, is an excellent idea.
Originally Posted by sldbyuramg View Post
doesnt effect emissions...that is correct. but it effects "smog" standards for CA
and to correct you for saying "stupid CARB" CARB is the board that allows californians to have aftermarket parts as long as it meets there requirements. if we didnt have CARB we wouldnt be allowed to modify anything in CA.
No... The CARB works their asses off to make modifying cars here a pain in the ass. If you want to thank any one organization for allowing us to mod cars here in CA, thank SEMA. They fight with the CARB on a regular basis.
Originally Posted by Risu2112 View Post
Need some help with the rear end though, I really like the quaife's but I can't even find one for my application, also they are really pricey, failing that I might be looking at a 1.5 way clutch rear end, but like I said I'd rather have the quaife, I don't want one of the VLSD's though. :<
If any one has any advice on the rear end please drop it in here.
What will you be using the car for? Street/drag? Street/drift? Strictly daily?
Q45 diffs are great if you want rear end with taller gears.
http://forums2.freshalloy.com/showthread.php?t=172393
You can ditch the VLSD in the Q45 diff in favor of something better.
If you're fine with the stock gearing, I've heard good things about the ATS/Carbonetics 1.5 way LSD. They are pricey, though, unless you find one used.
If you're going to run very sticky tires and/or drag race the car, I'd suggest swapping to either a Q45 rear since it is good and strong, or swapping out the stock 6-bolt axles for the JDM 5-bolt axles, which are stonger than the 6-bolt axles.
lol, you're wrong as well. It varies from county to county.
-Kyle
Old 01-19-2008, 11:40 AM   #35
Risu2112
Risu2112 has a spectacular aura aboutRisu2112 has a spectacular aura aboutRisu2112 has a spectacular aura aboutRisu2112 has a spectacular aura aboutRisu2112 has a spectacular aura aboutRisu2112 has a spectacular aura about
The car is going to be used for daily driving pretty often, my intention is to optimize it for the track though, 1.5 way with a 3.08 ratio would be ideal. I don't really need it any higher than 3.08 since I'll be having so many traction issues as it is. I'll look into the ones you recommended. ^^
Risu2112 is offline   Reply With Quote
Old 01-19-2008, 01:11 PM   #36
ma71supraturbo
ma71supraturbo is an unknown quantity at this point
Send a message via AIM to ma71supraturbo
Wrong. There is a reason why it is hard to get a PO box in Trinity and Humboldt counties...
ma71supraturbo is offline   Reply With Quote
Old 01-19-2008, 03:37 PM   #37
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
The only good thing out of that shit hole is Korn and even it stinks now
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 01-19-2008, 07:23 PM   #38
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
so will a ref approve a LS1 swap into an S13/S14?
newer engine than chassis .. check
smog legal engine ... check
JRas is offline   Reply With Quote
Old 01-19-2008, 07:56 PM   #39
ma71supraturbo
Yes, assuming all the OEM smog stuff is there. You are allowed to fabricate different piping to make it work in your engine bay, but you have to use stock injectors/ecu/maf in addition to EGR, charcol cannister, and the # & placement of cats...
Old 01-19-2008, 09:07 PM   #40
Risu2112
With the exception of the headers I believe, not sure if your counting that with "piping" or not. The headers need to be factory, or CARB certified aftermarket.
Old 01-19-2008, 10:19 PM   #41
ma71supraturbo
They don't have to be factory if you can document that they wouldn't fit in their original configuration. But you will have to make sure the catalytic converters are in the same location(s) as the OEM manifolds (by location I mean same distance from engine so they warm up as quickly as stock). It is definitely more work (and some referees will discourage you), but it is possible.
Old 01-19-2008, 11:11 PM   #42
PhilthyS13
PhilthyS13's Avatar
http://www.smogcheck.ca.gov/ftp/pdfdocs/program_map.pdf
You learn something new every day.
Old 01-19-2008, 11:30 PM   #43
gigimow
gigimow is an unknown quantity at this point
Oh yes, by the way my engine has arrived, it was surprisingly complete! Hoping to get a clean bill of health on it within a week or so!
Clearly I need to have a talk with the shop about storing empty cardboard boxes on my engine, don't want them to dent my transmission housing >.>
Where did you end up getting your engine from?
gigimow is offline   Reply With Quote
Old 01-20-2008, 01:20 AM   #44
Risu2112
Came from a WS6 with about 60k miles that had just enough frame damage to not warrant repairing
Old 01-20-2008, 01:37 AM   #45
drftwerks
how much if you dont mind me asking, you can pm if you want
giantroboteyes.wordpress.com/
Old 01-20-2008, 09:28 PM   #46
StaticX27
StaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond repute
Since when were a 92 civic and a 99 civic the same chassis?
Maybe you should read what I wrote a little more closely. If a 92 civic DX came with a D16 in it, and a 92 civic EX came with a B16 in it, you can legally put said B16 into your 92 civic DX.
StaticX27 is offline   Reply With Quote
Old 01-20-2008, 10:10 PM   #47
GSXRJJordan
GSXRJJordan's Avatar
This was mentioned above, but I want to clear it up - with regard to the headers, the OEM ones do not have to be used, as they don't fit anything except F-bodys or Vettes.
But the configuration of all the emissions equipment has to be identical.
When I say emissions equipment, what that really means is the cats. That means no long-tube headers, no headers that make you re-route emissions plumbing, nothing. As long as you keep that in mind, you'll be A-OK with CARB.
Old 01-20-2008, 10:13 PM   #48
soreballz
soreballz's Avatar
Trader Rating: (22)
^^Are you retarded? When did I say that they were the same chassis?
Read this carefully: ANYTIME YOU SWAP A MOTOR INTO YOUR CAR THAT ISN'T THE OEM MOTOR FOR THAT EXACT YEAR AND TRIM LEVEL, THE SWAP NEEDS TO BE REF-APPROVED TO BE SMOG-LEGAL.
Now, I'm reading what you wrote a little more closely... And what you wrote is indeed, retarded. Firstly, the 92 Civic EX never came with a B16. In fact, no US model Civic had a B16 in it until the EM Si coupe came along.
Secondly, even if that Civic DID come with said B16, yes, you COULD swap that motor into the DX of which you speak, but it wouldn't be LEGAL without that BAR sticker.
Now, I'm going to give you the benefit of the doubt here, and assume that this little arguement is the simple result of your shitty reading comprehension skills, and thus, is a mere misunderstanding. With that said, I'm done here. Have a nice day.
-Kyle
Old 01-21-2008, 03:42 AM   #49
kingkilburn
Philosopher King
Would that mean no 180 degree headers for a swapped V8?
Old 01-21-2008, 09:07 AM   #50
StaticX27
And that's where I consider you wrong. I can take my 7th gen Celica GT down to the dealership and drop in a 2ZZ motor and not even have to make a trip to the state ref, because of the first part of the law that you pointed out. It does not need to be ref approved.
Sorry, my honda knowledge is limited, poor example.
Maybe, or maybe you're wrong. Since you seem to be that interested in it, lets see the vehicle code that supports your statement. Otherwise I'm just going to assume you're another jackass.
Old 05-02-2008, 09:47 AM   #51
silbeer
silbeer's Avatar
silbeer is an unknown quantity at this point
Any updates?
Originally Posted by blu808 View Post
I can do a carb legal lsx-240 swap if you need any work done. Custom (carb legal) headers, wiring, hp tuners ecu editing, etc.
Risu I would recommend at least talking to Luke @ SDP. I visited his shop regarding the same project a few months back. I left with a positive impression of him and his shop. When I was there they had an FC getting prepped for a CARB legal swap, although I haven't followed up on that.
I never followed through because another project drained my budget. I'm saving up so that I can do this swap as well, so I'm definitely interested in following your project.
silbeer is offline   Reply With Quote
