Old 01-25-2008, 09:14 AM   #1
C-unit
C-unit's Avatar
C-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to all
RB25 series II ECU problem...
Hi, i picked up a auto RB25 series II motor for cheap. However, it doesnt come with the harness and ECU. To my understanding, the series II doesnt have an ignitor chip and its internally bebuild in in the ECU. What i wonder is If i can use a Series I harness and Series I ECU? It is very hard to find a series 2 ECU, so I wonder if i can use a series I harness and run an external ignitor chip. Any input will be Great.
Instagram CW_unit
C-unit is offline   Reply With Quote
Old 01-25-2008, 01:24 PM   #2
kouki_s14
kouki_s14's Avatar
kouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfection
Send a message via AIM to kouki_s14
You have a few things mixed up here. The Series 2 RB25 has a ignitor chip built into the coilpacks not the ECU. People have used Series 1 ECUs on Series 2 motors without any problems. So you should be fine running a Series 1 harness and a Series 2 ECU.
kouki_s14 is offline   Reply With Quote
Old 01-25-2008, 09:04 PM   #3
C-unit
C-unit's Avatar
Oh..thanks for the info. is it possible to use a series I harness with a series I ECU?? Is there any problem using a Manual ECU because the engine is from an auto laurel.
Instagram CW_unit
Old 01-25-2008, 09:26 PM   #4
kouki_s14
kouki_s14's Avatar
Do you mean a series 2 harness with series 1 ecu? If it works one way it should work the other way.
Engine harness should be the same, you need to worry about the transmission harness.
Old 05-17-2008, 02:53 PM   #5
gunmetalr32
gunmetalr32's Avatar
gunmetalr32 is on a distinguished road
i have a series 2 ecu....and a series 1...pm me if you need them
gunmetalr32 is offline   Reply With Quote
