![]() Hello people i really need your help. Please dont say i need to search cause I DID MAY TIMES! if i found my answer i wouldn't be posting. i did my wiring harness using http://mysite.verizon.net/nrgonline/s13sr_to_s14.htm I put my harness in 2 weeks ago but no start
i used the same instructions when i did my harness and it worked fine. Make sure to check all your fuses, you may have hooked a wire up wrong and popped a fuse. Also make sure to check all your grounds and run more grounds. Im sure its something simple but you have to check everything. The radio and clock not working makes me think a fuse is blown.
My fuses are good. i checked. Do you have ground wires for F3 plug or ECU plug? i found some black wires from my ECU plug and i ground that sucker up. you know when i turn my key i hear a click. can it be my starter? may be my ingnitor chip? how can i tell my ingnitor chip is bad? help me please cause im going crazy thinking about this problem that i can not solve.
![]() Join Date: Jun 2006
pull the starter and bench test it. Test your batt too. One or the other, if its clickING either the starter is to weAk to turn the motor over, or the batt is to weak to turn the starter
btw, that's not my writeup, i just backed it up because the main server of that guy kept going down. I've verified that the writeup is correct to every aspect. On the F3 plug, you should only use the wires you need. There's only one ground wire on the harness.
i have my own version of the wiring somewhere on my server; i'll look for it tonight. the engine harness has nothing to do with your radio or interior crap. when the wiring is done, it just looks for starter signal, ground, power. then the instrumental signals for like tach, temp, gas gauge, speed.
![]() driftingisgay.com |
i think you misunderstood what i was saying. Some wires from F3 plug was already connected to ECU wires. I am not saying the write up is wrong. like i said my friend used the same write up and his car works fine. i just dont know what i did wrong. checked and everything is fine. maybe i over looked something. about the radio and my clock i have no idea whats wrong with it. But Thanks NRG i hope you can find me your write up so i can check again. sorry people no pics today. i didnt have time sorry. tomorrow for sure. please if you have any idea about the clock/radio/my car not starting please help. Thanks.
#10 | |
here's my version; wiring is the same as that page. just hope you understand mine alittle better: http://www.driftingisgay.com/img/s13sr_in_s14.jpg when i mean "power plug" i mean the F3. that's where all the connections go to for power on the s14. the instrumental plug at the end of the s13 sr20 harness. do not cut that, it's best to find an s13 dohc and cut the male end from there. or if you pull it from a front clip, cut that piece. so you will wire that up to the F3 plug. The relay comes off the s14 ka harness, cut that and wire it. wiper motor, you just extend it and wire it up to the F3 plug, easy. the gray and brown harness that is usually pluged in the battery area of the S13 engine bay? well those wires gets pulled into where the ECU is and wires up to the F3 harness. very simple stuff.
Hey people i got my car CRANKING!!!!! It was my starter.
1. got the starter tested it was fine 2. put the starter back on and tried again but no luck ( Good starter but no crank? didnt get it ) 3. I GOT MAD and i hit the starter with FREAKING HAMMER TA DA!!!!!!! if it doesn't work, just bang it with the hammer. hahahaha. If only i can hit my radio/ clock its still not working ![]() anyway now my car cranks but my fuel pump is not working. i know before i said my fuel pump was working but NOT no more. any ideas? ahhh kill me now. Sorry i cant DL my harness pics to my comp. but no pics today sorry. i think my harness dont like me ![]() |
#16 |
yes my car is running now! some of my wires wrong connected to wrong. thanks man. man my car smokes like crazy. ewww. lol but its koo its running now thanks people for helping me. +1 for nrg and ho1ywars. hahah
