Old 02-10-2008, 09:15 PM   #1
ncrk
ncrk has made poor choicesncrk has made poor choicesncrk has made poor choicesncrk has made poor choicesncrk has made poor choicesncrk has made poor choices
Send a message via AIM to ncrk
SR new boost gauge reading 20 lbs vaccum?
ok, i just "installed" an autometer boost gauge, and i drove my car for the first time and it reads between 10 and 20 lbs of vaccum
i doubt my car is pulling 20 pounds
if it helps, my turbo is the t25 that comes stock with the redtop sr20
any help would be cool
thanks
ncrk is offline   Reply With Quote
Old 02-10-2008, 09:16 PM   #2
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
Wrong section.....Unless you're selling it.
duffman1278 is offline   Reply With Quote
Old 02-10-2008, 09:19 PM   #3
ncrk
nevermind guys....
Old 02-10-2008, 09:41 PM   #4
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
for future reference 20 lbs of vacuum at idle is normal
projekt_s13 is offline   Reply With Quote
Old 02-11-2008, 02:47 AM   #5
Def
Vacuum gauge on most imperial unit gauges is in-Hg(inches of mercury), and yes, -20 in-Hg at idle is normal for stock cams. For more bumpy cams you can get anywhere from -10 to -15 in-Hg.
Old 02-11-2008, 02:14 PM   #6
ncrk
but it says 20 pounds when im driving it too
Old 02-11-2008, 02:20 PM   #7
stupid nissan
stupid nissan is on the path to ruinstupid nissan is on the path to ruin
is it 20 lbs of boost or is it vacuum they are to different things
stupid nissan is offline   Reply With Quote
Old 02-11-2008, 02:24 PM   #8
corriganjoshua
corriganjoshua's Avatar
corriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfection
Send a message via MSN to corriganjoshua
it says 20 ibs vac when your driving i take it, it reads that when you hit boost as well?
Team Inertia
Cheap,Fast,Reliable you can only have 2.
corriganjoshua is offline   Reply With Quote
Old 02-11-2008, 02:24 PM   #9
ncrk
vaccum.........
Old 02-11-2008, 02:25 PM   #10
ncrk
yep...........
Old 02-11-2008, 02:26 PM   #11
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
What vacuum source are you using for the boost gauge?
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 02-11-2008, 02:28 PM   #12
SoSideways
SoSideways's Avatar
Please use the correct terms when you refer to vacuum or boost, because you will confuse people if you don't.
Vacuum is measured in inHg (inches of mercury) on most imperial gauges, just like Def said.
Boost in measured in PSI (pounds per square inch) on most imperial gauges.
Please listen to Def as he is a helluvan engineer, and he knows what he's talking about.
20inHg of vacuum on a stock car is good.
I don't even get 20inHg. I get like 17 to 18 inHg.
Old 02-11-2008, 03:29 PM   #13
g6civcx
g6civcx's Avatar
Take a picture of the gauge with the engine off and at idle. Do not try to take a picture and drive at the same time, or at least don't blame us if you crashed.
Old 02-11-2008, 04:46 PM   #14
ncrk
k, sorry guys im new at this
when its idle it sits at 0 ad when i get on the throttle it goes up to 10-20 inHg of vaccum
when the turbo kcks in it shows about 20inHg
so thats a good thing?
i thought i should be having press.
Old 02-11-2008, 04:52 PM   #15
Kouki
Kouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud of
Either you got a bad gauge, or you tapped into the wrong spot for your vac source. You should be around 20inhg at idle, and under boost it should go up into boost psi. Is this a mechanical gauge? Where did you tap into for the vac source?
Kouki is offline   Reply With Quote
Old 02-11-2008, 04:56 PM   #16
ncrk
i tapped in right off of the blow off valve
im getting the feeling i did something stupid?
Old 02-11-2008, 05:11 PM   #17
lazierhobo
lazierhobo is on the path to ruinlazierhobo is on the path to ruin
so as you come into boost, there is no change in the readings?
lazierhobo is offline   Reply With Quote
Old 02-11-2008, 05:14 PM   #18
ncrk
there is a cange
it goes up to 20
Old 02-11-2008, 05:16 PM   #19
johngriff
johngriff's Avatar
If it is -20 at WOT.
There is a big issue, no matter what the vacuum source is, even if it is N/A
[email protected]
Old 02-11-2008, 05:20 PM   #20
ncrk
is the blow off valve not the place to tap into the vaccum??
Old 02-11-2008, 05:21 PM   #21
Kouki
If it's an electrical gauge maybe you wired it backwards?
Old 02-11-2008, 05:24 PM   #22
ncrk
i think its mechanical cause it uses the nylon tube
but it might be electrical for all i know
Old 02-11-2008, 05:54 PM   #23
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
take a picture.
it cant be right if your gettin nothing at idle.
take some pix of how you got your vac lines routed
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 02-11-2008, 07:00 PM   #24
2fast4y0u
2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore
just follow this...
Where do the vaccum lines on an SR20DET go?
The vaccum diagram for the SR20DET is wonderfully simple. Thank god. There are only 3 vaccum lines that are absolutely necessary. Most mildly modified SR20's will have 4-6 depending on what extras are added on. Lets begin.
Throttle Body:
The throttle body has 3 vaccum sources coming off of it. Two above the throttle plate, and one below. The top left vaccum source is for the fuel pressure regulator. Also, if running a boost gauge (like you should), you will need to T off of this source to get the boost gauge signal. The top right vaccum source is for the Recirculating or Atmospheric Blow Off Valve. Lastly, the bottom left vaccum source is for the carbon canister. However, a lot of SR swaps will have this capped off because not having it isn't going to make us fail emissions. We fail anyways! The large hose above the throttle body that connects to the intercooler cold pipe is for the idle. Please hook it up; your SR will thank you.
Wastegate:
The wastegate gets it's signal off of the charge piping (aka Intercooler Piping). The stock piping has has a nipple on the cold side for the wastegate. Blitz and HKS front mount kits have a nipple on the hot side, and GReddy or custom intercooler kit will need to have a nipple welded in on the hotpipe (or somewhere else on the charge piping). If you are going to run any sort of boost controller, the boost controller needs to sit in the "middle" of this vaccum source. Meaning that you will need to have the nipple on the charge piping go to the "In" side on the boost controller, and the "Out" side needs to go the wastegate actuator. I don't have a boost controller on mine, thus I run a vaccum source directly from the charge piping to the wastegate.
Boost Solenoid:
This oddity sits on the ignitor chip plate. If you got a clip, yours was probably hooked up. Well... you don't need it when you swap it into your USDM chassis. Cap them off or take it completely off and do whatever you want with it. I suggest feeding it to your dog.
the website this was on is not going to availble anymore. so here it is.
Jay
2fast4y0u is offline   Reply With Quote
Old 02-11-2008, 07:05 PM   #25
Kouki
Did you buy the gauge new? What gauge is it? Does the car seem to run fine, pull good up top, and idle smooth?
Old 02-11-2008, 07:25 PM   #26
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
i don't think you fully grasp the difference between vacuum and boost. When your engine is turned off, the gauge should be at 0. (atmospheric pressure). When you fire it up, it will go down (to the left, into vacuum). It is normal to be around 15-20 mmHg when idling. Most of the time while you're just cruising, it will be in vacuum, and begin to rise with slight throttle inputs. When you step on it, it should go past the 0, and into a new set of numbers (psi, to the right of the 0) which is boost.
Does your gauge stay below 0 the entire time?
that's sweet you live in garden grove...where is that? does it smell like lou dog inside your van?
96Turbo is offline   Reply With Quote
Old 02-11-2008, 09:23 PM   #27
Def
^ Exactly, "zero" on your gauge corresponds to atmospheric pressure. Anything below that is "vacuum" or lower than atmospheric, while anything above is higher than atmospheric.
Units below are probably in-Hg of vacuum, while units above are probably PSI(pounds of pressure per square inch).
There is a BIG difference beyond "it goes to 20" when it is on either side of zero.
Also... what type/brand of gauge do you have?
I tried to tune a guy's KA that had too many ebay parts on it, and the boost gauge was basically a good random number generator. He thought it was cool as hell when it went to 35 psi when you went WOT at 2.5k RPM though...
Old 02-12-2008, 06:57 AM   #28
SHIFT_*grind*
When you say you tapped it "right off of the blow off valve," do you mean you just ran the hose directly from the gauge to the vacuum nipple on the BOV, without T'ing it off? You sound pretty clueless about all of this so I thought I would ask. If that's what you did, it's definitely wrong. The BOV isn't the best place to T off from, anyway.
Follow 2fast4you's instructions up there and as long as it's not broken, the gauge should work fine.
Old 02-12-2008, 07:11 AM   #29
M374llic4
M374llic4 is an unknown quantity at this point
Send a message via AIM to M374llic4
If I am not mistaken you need to put a line from your intake manifold on that nipple on the bov to hold it shut under boost, otherwise when you hit boost the bov will just open and vent all your charge?
M374llic4 is offline   Reply With Quote
Old 02-12-2008, 08:12 AM   #30
ncrk
i T'd it off, i know that much haha
and yeah im new at this whole thing
thanks for all the patience though
