Old 02-13-2008, 09:31 AM   #1
LA_phantom_240
LA_phantom_240's Avatar
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
Headlight removal
How do I remove the headlights on my zenki s14? I see two small bolts close to the grille end of the headlight, but I'm wondering if there are any others I need to remove as well (other than the corner lamp assembly)? On my 90 Acura Legend I had to drop the bumper to get the headlight off... and the FSM did no good, as well as the search function.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 02-13-2008, 09:33 AM   #2
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
There are 4 bolts total to remove each headlight. 2 by the grill and then 2 behind the corner lights. After that, just unplug the bulb harness and it will come out.
garagelu is offline   Reply With Quote
Old 02-13-2008, 09:56 AM   #3
LA_phantom_240
Good... Now I can finally make my right headlight look good again. My left is new because it got broken in a fender bender before I bought it. My right, however is getting a little foggy.
Old 02-13-2008, 09:57 AM   #4
steve shadows
steve shadows's Avatar
I used a Sawzaw
Like Me on FaceBook !
Old 02-13-2008, 10:01 AM   #5
LA_phantom_240
Originally Posted by steve shadows View Post
I used a Sawzaw
Duly noted.
Old 02-13-2008, 10:18 AM   #6
MavericStephenc
MavericStephenc's Avatar
MavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfection
Send a message via AIM to MavericStephenc
remember to be careful when taking the corner light, and the headlight as well. you don't want broken tabs!
That kind of attitude is SHIT. People with that kind of complacent outlook on law and government are the bane of this country's existence. -Thesquidd
Boycott Berkeley and code pink
MavericStephenc is offline   Reply With Quote
Old 02-13-2008, 10:20 AM   #7
LA_phantom_240
The corner light is easy. I had to change the bulb in it when I got it. The only way I could think of to change the bulb is to take the whole corner lamp off.
Old 02-13-2008, 10:24 AM   #8
MavericStephenc
that would be correct. g/l cleaning up the lenses
Old 02-13-2008, 11:32 AM   #9
LA_phantom_240
I got my 2000 grit and polishing compound ready to go.
I may experiment with a durable, UV resistant clearcoat.
Old 02-13-2008, 12:47 PM   #10
LA_phantom_240
WOW! What a difference. 2000 grit + soapy water + 20 minutes = No more surface imperfections. It leaves the headlight looking mighty hazy, but paves the way for further action. 30 minutes with polishing compound, and the headlight is looking damn good. Close to new, in fact. Then top it off with clearcoat made for wheels, and it looks exactly like new once you let it cure and then hit it lightly with polishing compound and then a coat of wax.
Pics when I can find my camera cord.
Old 02-13-2008, 01:03 PM   #11
MavericStephenc
what polishing compound did you use?
Old 02-13-2008, 01:10 PM   #12
The Chad
The Chad's Avatar
The Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really nice
^^ def curious, as i have one new light and one old one...the old one allways ends up yellowed again soon after i sand it/buff it out...abt 2 months later. What kind of clear did you use, i.e. brand and type??? Thanks ahead of time.
--Mav, your sig still gets me man, i def need a fun sig...hmmmm...
The Chad is offline   Reply With Quote
Old 02-13-2008, 01:14 PM   #13
LA_phantom_240
I used Turtle Wax polishing compound, and a microfiber wax applicator from AutoZone. Soak the applicator and wring it out, then go to town with the compound. I used a hair dryer to dry and heat up the headlight, then I used that Duplicolor Wheel Paint. Clear, of course. I did a thick layer by slowly adding light layer by light layer, about 45 seconds after another. I then used the hair dryer again to heat and speed the curing process, then let it sit a while. Pressed on the paint to make sure it had hardened all the way, and went to town on it with the compound, washed it, and waxed it.
Old 02-13-2008, 01:15 PM   #14
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
PICS OR BAN!!! Curious to see how well it turned out compared to the brand headlight...
CLICK HERE!!!
Old 02-13-2008, 01:27 PM   #15
LA_phantom_240
I don't have any 'before' pics, because the only pics I have are when I first got the car, and it wasn't that bad then... but just imagine your 'typical' cloudiness. Nothing life-threatening, but ugly nonetheless.
Whadayathink?
Old 02-13-2008, 01:59 PM   #16
aznpoopy
aznpoopy's Avatar
looks good. but you have to keep up with it, or else it yellows over again. ask me how i know... >.>
Old 02-13-2008, 02:30 PM   #17
LA_phantom_240
Even after clearcoating it?
Old 02-13-2008, 03:52 PM   #18
The Chad
The Chad's Avatar
^^^ yeah i was under the impression that if you cleared it, it wouldn't fade...or at least last longer??
+1 btw for the Invader Zim pic
Old 02-13-2008, 04:29 PM   #19
aznpoopy
aznpoopy's Avatar
i never tried clear coating it before. seems like it should last longer. let us know how it goes
Old 02-13-2008, 04:46 PM   #20
LA_phantom_240
Will do, good sir.
Old 02-14-2008, 09:24 AM   #21
MavericStephenc
nice n' clean good job and do let us know about how long it lasts
chad, did you get my message about the PA meet?
Old 02-14-2008, 05:11 PM   #22
The Chad
The Chad's Avatar
Def let us know how long it lasts...if i have to keep sanding my headlights there will be nothing left!!!! haha
Nope, i did not Maveric. Pm me please i think my box was full. If its a big meet i might make the trek .
Old 02-14-2008, 06:47 PM   #23
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
i do/did the same thing. bit when i do it i just use mothers mag polish and a clean rag. scrub the headlight wiht the mag polish on it and once it is clear enough for you put wax on it. any kind of wax works. i done this like 3 or 4 moths ago and mine havent got yellow yet. the car has seen snow rain and sun.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
