Old 01-21-2003, 12:31 AM   #1
misnomer
misnomer's Avatar
Ticking under the valve cover at idle
I assume it's a timing chain issue, I don't know what else under there would be causing it. The motor rattles/ticks at idle, but smooths out when given a little gas. I can hold it at 1000 rpms and don't hear anything.
Is this a serious enough problem that I should deal with it immediately, or ever? :P I've heard about this before, so figure it's a fairly common issue. Are the upper timing chain guides all that need to be replaced, or do I need to pull the entire front cover off of the engine?
